header situation
Old Sep 23, 2007 | 03:32 AM
HemiSport's Avatar
HemiSport
Default header situation
i ordered jba headers but now i dont know what to do. i heard that the pipes are to skinny restricting flow. need info asap thanks.
Old Sep 23, 2007 | 08:04 AM
BlackZ51Vett's Avatar
BlackZ51Vett
What size are the pipes ? If they're at least 1 3/4" - 1 7/8's I'd say they are prob fine.
Old Sep 23, 2007 | 11:58 AM
HemiSport's Avatar
HemiSport
the pipes are 1 5/8 long tubes
Old Sep 23, 2007 | 12:12 PM
EuroRod's Avatar
EuroRod
I hope you mean 1 5/8" in diameter. Most header fabricators are using 1 3/4" tubes for the LS2.
Old Sep 23, 2007 | 12:15 PM
HemiSport's Avatar
HemiSport
yes the diameter is 1 5/8" what do you think i should do people or what headers do you recomend
Old Sep 23, 2007 | 03:02 PM
HemiSport's Avatar
HemiSport
more on the headers. please what do i do good bad . will other headers perform significantly better. asap please for i might have a chance to cancel order
Old Sep 23, 2007 | 03:11 PM
Vito.A's Avatar
Vito.A
LG Motorsport just did a test with 1 3/4 vs 1 7/8 primay tubes and the smaller tubes were superior. 1 5/8 will certainly outperform your stock exhaust, but may not be the very best.
Most experts think that a stepped header 1 5/8-1 3/4-1 7/8 with a merge collector is the optimum header for a 6-7L motor operating in the 4-7000 rpm range, but this is running without cats or mufflers.
Old Sep 23, 2007 | 03:26 PM
HemiSport's Avatar
HemiSport
thanks for the info it
To header situation
