Anyone using waterwetter?
Old Sep 24, 2007 | 12:55 PM
csun213's Avatar
csun213
Default Anyone using waterwetter?
Just wondering if using waterwetter will lower my water temperture?
If so, can someone tell me where to purchase it?
Old Sep 24, 2007 | 12:59 PM
edv2122's Avatar
edv2122
I put in two bottles of water water when I changed my stat to a 160*. Of course my temps dropped but I think it was mostly from the stat and fan reprogram rather then the water wetter.
edv2122's Avatar
edv2122
Got mine from Pep Boys
Old Sep 24, 2007 | 01:34 PM
csun213's Avatar
csun213
Thanks.
Old Sep 24, 2007 | 01:51 PM
rallyred65's Avatar
rallyred65
It works very well, I use it in all my cars.
Old Sep 24, 2007 | 02:17 PM
6Speeder's Avatar
6Speeder
It does work, but only on water, not coolant. So, running it with 50/50 coolant you won't see as much effect. I switched to 25% coolant 75% water and one bottle of water wetter when I put in my 160 thermostat.
Old Sep 24, 2007 | 02:41 PM
csun213's Avatar
csun213
Here in the San Francisco area where we don't really go below freezing plus I always garage my car, would be OK to go either 50/50 water and waterwetter, or 25 coolent and 75 waterwetter?
I just want to drop my water temp in my superchargerd A6.
Old Sep 24, 2007 | 02:57 PM
LloydP's Avatar
LloydP
This comes up periodically, For the street, follow the factory recommendation. The water pump lubricants and corrosion inhibitors will preserve your investment. If you want lower temps, put in a 160 thermostat.
Water wetter is mostly a soap solution, It delays the onset of nucleate boiling around the upper cylinder at full throttle. Use as recommended on the race track to keep from spilling slick coolant on the track. Otherwise it is a waste of money. (I know it is your money and I agree)
Old Sep 24, 2007 | 04:33 PM
EuroRod's Avatar
EuroRod
The smaller concentration of anti-freeze, the more efficient water wetter will be. Works best with distilled water only. If you're running a 50/50 mix, save your $$$$.
To Anyone using waterwetter?
