I wanted to get some cooler air to my Halltech Stinger. I never did undersatand the cool air mod, so I got out my drill. (it's the same on the other side) It looks fugly, but you can't really see the holes unless you're looking for them. I swear I could feel it pull harder at WOT on the freeway, but it may have been the placebo effect. Oh well, flame suit on.
Get a vette air , Sorry but your right I would order the replacement panel, that does look horrible!
There were some threads in the past about "free cold air". Do a search.
Basically, you pull the 2 plastics pins holding the bottom of the shroud. Then you can pull back/down the shroud and prop it open creating your own ram air. I used wooden dows. I cut them about 5 inches long and proped open the shroud using the same holes where the plastic pins were located.
Works great! You can not see it either unless you are on your knees looking through the front grill.
