H Pipe or X Pipe
Old Sep 25, 2007 | 02:22 PM
wayback's Avatar
wayback
Default H Pipe or X Pipe
I have the Corsa Touring X pipe on my 07 AW Coupe that was on my 06 Vert. I would like a little more sound with the Coupe than I wanted with the Vert. Corsa Sport X Pipe is expensive. I can buy a stock H Pipe very reasonable.
Is there any performance difference between the two that I could feel SOTP? Or only at the track?
Old Sep 25, 2007 | 08:26 PM
MarylandSpeed's Avatar
0MarylandSpeed
Former Vendor
I like H-pipe sound...it's a little deeper. That being said, it also flows slightly less efficiantly than an X-pipe.
www.MarylandSpeed.com- Unmatched Service & Great Prices!
We Have a Sale on Kooks Headers Going!
Current Poject- 2007 Loaded Machine Metallic LT3, A6 Targa (Not Stock)
Old Sep 26, 2007 | 02:29 PM
sscamaro's Avatar
sscamaro
St. Jude Donor '07
Put your stock H-pipe back on the car. It will get a little louder.
Old Sep 26, 2007 | 05:21 PM
CMY SIX's Avatar
CMY SIX
the x-pipe does give you hp.
Old Sep 26, 2007 | 06:30 PM
redrokit8's Avatar
redrokit8
If you put the H pipe on now,you will always have the X pipe on your mind and eventually break down and put it on anyway.
Do the X now-not later.
I'll betcha!!!!!!!!!!!!
Old Sep 26, 2007 | 09:06 PM
HemiSport's Avatar
HemiSport
H pipe does not flow as well . X pipe allows for a smoother exhaust flow
.on the h pipe exhaust has to make 90 degree turn . on the x pipe it does not have such an abrupt angle. look at it and in your mind picture x and h exhaust flow. either one is great they help balance exhaust pressure.
ps. go with x scrap the h
correct me if im wrong
Old Sep 26, 2007 | 09:39 PM
Silverspeed's Avatar
Silverspeed
St. Jude Donor '13, '15
You will notice ZERO difference in performance with either. The H pipe will give you a little more crackle on decel than the X pipe. Email Corsa's technical sales on their website(Paul). He'll probably tell you the same thing. Of course they will also tell you that you will get 10-12 rwhp with a catback, which I don't believe for a second.
Old Sep 26, 2007 | 11:01 PM
wayback's Avatar
wayback
I purchased a stock H pipe from atomicC6 and he even delivered it this morning. Thanks Shaun
I will put it on and keep the corsa x pipe. Maybe I can have the baffels removed if I feel it is needed.
Thanks for the replies.
To H Pipe or X Pipe
