Header install question
Old Sep 26, 2007 | 09:51 PM
Finster07's Avatar
Finster07
Default Header install question
I am in the middle of a header install and noticed when removing the bolts from the original exhaust manifold that they were very stiff all the way out. That being said, when I reinstall the manifold bolts on my eaders, should I use an anti-seize compound? Is the temp too high for this?
thanks
Old Sep 26, 2007 | 10:16 PM
Silverspeed's Avatar
Silverspeed
St. Jude Donor '13, '15
Read this article:
http://www.gmhightechperformance.com...r_installation
It states that the factory bolts come loaded with sealant that needs to be removed(thats why they came out hard). It also suggest's using thread locker as header bolts tend to loosen over time.
Old Sep 26, 2007 | 10:36 PM
Joe Lynch's Avatar
Joe Lynch
St. Jude Donor '09-'11
Clean every bolt with a fine wire brush or wire wheel. Use anti-seize on the threads. Suggest you run a bolt doen every bolt hole in the heads to make sure the sealer is clear on the holes.
If you use the stock style metal gaskets, you should not need to use thread locker, just anti-seize. I have 8000 miles on mine since header installation and no loosening.
You must clean the bolts and chase the threads in the heads, however. Be very careful starting all the bolts.
Joe
Old Sep 26, 2007 | 11:47 PM
Finster07's Avatar
Finster07
Originally Posted by Silverspeed
Read this article:
Thanks for the article. That is exactly what I needed.
Old Sep 27, 2007 | 05:40 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
with all the comment thus far. i will add that you should re-torque the header bolts, etc. after a couple of heat cycles. go for a couple of nice long drives then let her cool and re-torque.
personally, i don't use the anti-seize, how often will i be removing them??
and yes, be very careful starting the bolts, aluminum is soft and cross threading is easy.
Old Sep 27, 2007 | 06:57 AM
EuroRod's Avatar
EuroRod
Use anti-sieze on the header bolts, or any time you are bolting into aluminum! Period!
Old Sep 27, 2007 | 08:58 AM
jterp's Avatar
jterp
So one group says to use anti-seize, the other says to use thread locker.. Good old corvette forum -- always there to make you even more confused!
Old Sep 27, 2007 | 09:40 AM
Joe Lynch's Avatar
Joe Lynch
Try just the anti-seize. You can always go back to thread locker if they loosen.....which they won't, if you use the stock style gaskets.
Joe
Old Sep 27, 2007 | 09:52 AM
haljensen's Avatar
haljensen
My Dynatech headers instructions said to use anti-seize with the supplied gasket and new header bolts. They have been on the car for two years now with no problems.
Old Sep 28, 2007 | 11:16 AM
Finster07's Avatar
Finster07
You are correct, everyone has an opinion and then I get to choose what I like the best. For whatever it is worth, I called Kooks and spoke to their technical guru. Very informative and told me he had all the time I needed for all my install questions. He went on to say anti-seize was what they recommend on aluminum blocks. He said worst case if you use lock-tight, you could run the risk of striping the threads on the block if you ever had to take it off for any reason. That being said, I would rather use anti-seize and see if the bolts hold rather than doing something irreversible to the block with lock-tite.
Thanks for the choices.
To Header install question
