higher compression
Old Sep 27, 2007 | 06:57 PM
HemiSport's Avatar
HemiSport
Default higher compression
thinking about a higher compression piston set up. any info: open to any suggestions bigears
Old Sep 27, 2007 | 10:15 PM
HITMAN99's Avatar
HITMAN99
Swapping out internals like pistons is expensive, and not worth it unless you are also contemplating other mods.
First, you can raise your compression much more easily by milling the heads .030", and/or installing a thinner Cometic head gasket. However, the higher compression will just result in possible preignition/pinging, unless you get a computer tune, and retard your timing. Retarding the timing will reduce your power, thus eliminating any gains from the higher compression. Yes, you can address this issue by running race gas, or with an additive such as Torco, but neither is very suitable for the street.
You could also run an alcohol/water injection system, fed by a tank mounted in the rear of the car. Such a system is currently being touted on this forum in a current thread.
Raising compression is usually done in conjunction with an aftermarket cam with longer duration. The cam timing has the effect of lowering the dynamic compression, so static is raised to compensate.
Raising compression by itself is not a good idea. Doing it with aftermarket pistons is a really bad idea.
Old Sep 27, 2007 | 10:32 PM
huckleberrydude's Avatar
huckleberrydude
Next motor will have lower compression for me.
Old Sep 27, 2007 | 11:15 PM
HemiSport's Avatar
HemiSport
thanks for the reply. will take into consideration everything everyone writes.
Old Sep 27, 2007 | 11:29 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
When I put in my G5x3 cam I put in Cometic .040 gaskets to raise compresion to about 11.4 with DCR of about 8.2 (I forget the exact DCR number). I did this to keep my low end torque close to the same in my daily driver. I've also been told that the thin gasket reduces quench area and allows me to run more timing without pinging, which is true because I can run quite a bit without KR.
It worked. I actually gained a little low end torque below 4k even with the big cam. My torque curve remained basically the same.
Here's my write up and dyno sheets.
http://forums.corvetteforum.com/show....php?t=1769681
To higher compression
