Idle question
Old Sep 30, 2007 | 07:37 PM
saplumr's Avatar
saplumr
Default Idle question
I was out this evening and noticed out of no where, at a stop idle the RPM's fluxuate up and down and then stall. Also seems to have a throttle hesitation from a starting stop. Checked a little later after I got home and it seems to be OK. Any ideas what the problem might be?
Old Oct 1, 2007 | 03:25 PM
carpe dm's Avatar
carpe dm
Bad gas? Keep an eye on it; you may have to do an idle re-learn, or you many have a bad IAC unit. Hopefully it was just a hickjup.
Old Oct 1, 2007 | 08:34 PM
oneblackvette's Avatar
oneblackvette
IAC on a C6?
Remove battery cable and let idle trims reset if problem continues will need to look further. When was the last time you cleaned your MAF?
Old Oct 2, 2007 | 09:22 AM
saplumr's Avatar
saplumr
Originally Posted by oneblackvette
IAC on a C6?
I had the ProCharger intake pipe apart recently and MAF screen is like new.
To Idle question
