Need 18" rear wheels for 05
Old Oct 7, 2007 | 12:53 AM
tmak26b's Avatar
tmak26b
Default Need 18" rear wheels for 05
Looking for rear wheels in 18" with the offset like the stock 19s. Have you guys seen them? I need to downgrade for racing
Old Oct 7, 2007 | 10:13 AM
stanleyp's Avatar
stanleyp
Try looking for "take-offs" from a Caddie XLR. They're 18".
Old Oct 7, 2007 | 10:18 AM
not08crmanymore's Avatar
not08crmanymore
try the c5 section,too.
Old Oct 7, 2007 | 11:14 AM
haljensen's Avatar
haljensen
18" X 10" X 79mm don't exist except in custom orders. You'll pay as much per wheel as you'll pay for a set of 4 (F&R) 18" and 19". If you want F&R 18" to match in stock offsets look for $3200 and up for 4 wheels.
Old Oct 7, 2007 | 07:49 PM
Rickard's Avatar
Rickard
Default Try TomzWheels
I bought C6 replica wheels from TomzWheels in 18" size for the rear for my 2006 C6 so that I could run track tires. They work great.
At the time they were only available in chrome so I simply painted them. No problems after two seasons.
Old Oct 7, 2007 | 10:46 PM
tmak26b's Avatar
tmak26b
The XLR runs 18x8, I dont think anyone has 18x10.5. C5 wheel has a 53 offset, i want the 79 offset like the stock 19s. I don't see any wheels listed for the Vette on Tomzwheels
Old Oct 7, 2007 | 11:39 PM
dennis50nj's Avatar
dennis50nj
you need 18x9.5x65mm it will fit fine and wont stick out i use 295x35x18 bfg drags
Old Oct 8, 2007 | 07:33 AM
Rickard's Avatar
Rickard
You are right - I don't see them listed on Tomzwheels anymore, either. However, if you do a search for "C6 replica chrome" you can find others out there. You might try contacting Tomz or check the other forum vendors. They are definitely still available.
Old Oct 8, 2007 | 10:14 AM
AndyF-Dallas's Avatar
AndyF-Dallas
Get a pair of C5 Z06 rears (18x10.5). I run them all the way around for autocross with 315x30x18 Hoosiers. They fit and clear fine in the rear of my 2006 C6 Z51. Fronts require 1/4" of spacing in order not to rub full lock and I have car lowered as much as possible without fender lips rubbing.
Old Oct 8, 2007 | 05:28 PM
tmak26b's Avatar
tmak26b
The C5 wheels have a 55mm offset, I really don't want to change it by that much, especailly for track use.
Old Oct 8, 2007 | 05:39 PM
tmak26b's Avatar
tmak26b
From what I can see, all the C6 replica wheels have 55mm. Are there any with 79mm offset?
Old Oct 9, 2007 | 07:01 AM
Rickard's Avatar
Rickard
Don't forget that a wheel that is 9.5" wide will need a different offset than a 10" wheel to have the same placement in the wheelwell. If you go with a 9.5" wheel you will not want a 79mm offset.
Old Oct 9, 2007 | 07:52 AM
dennis50nj's Avatar
dennis50nj
trust me 65 mm on the 9.5 will work fine the 10.5 rim with 58 mm will stickout to far. i have the 65mm 9.5 and it is perfect mo one can even tell. and 20 people have done it on the forum with the same results
http://www.1010tires.com/WheelOffsetCalculator.asp
Old Oct 9, 2007 | 10:46 AM
haljensen's Avatar
haljensen
That link is a great tool, thanks.
To Need 18" rear wheels for 05
