Just checked my '08 (3500 miles) since I was hearing some noises from the right rear. Left side was about 160 and the right was maybe 100...not sure as I have the clicker type torque wrench and didn't do it in steps to see what it was. I don't think this is the cause of the noise but I'm glad I checked.
I don't want to start a panic or any rumors but the right side was definitely not as tight as the left. I just don't know how loose unfortunately. My gut feel is that it was looser than the GM spec's would allow from the factory.
Anyhow, don't everyone get all because of this one data point.
My dealer (Mark Schols Chevrolet, ) mis-diagonised a frequency-based vibration as a differential issue, and replaced the entire unit with a brand new one. When this did not cure the problem, I asked if they had checked the axle retention nuts. They said no, the problem with the axle nuts was a Z06 specific issue. I insisted that the nuts be checked, and, bingo, right side was about 20 pounds, left side much less. Dealer replaced bearings and nuts, torqued them properly (151 ft lbs) and lock-tightened them down. Problem solved. I suspect loose nuts will evidentually cause bearing failure.
I used the 34mm socket that I had laying around from fighting the infamous ticking issue on my C5. I believe its from Autozone (not Pep-Boys like I originally said) but not positive. It fits a little loose but works fine.
