C6 replacement tires
My C6 needs new rubber soon, should I get the run-flats that came stock or I was thinking of maybe going with BF Goodrich KD-W's, my C6 is mainly driven in the summer and I may track the car a couple of times a year, which tires are the best for the C6 guys?
I kind of like the runflats for the rim saving. If your tires are non runflat, if you go very far at all on a flat. Your rim is gone too.
Run flats can help keep the car under control if you have a blow out at speed. Since that means they could save my bacon and others, I'll be going with them again.
I had a blowout at speed - about 80 mph on a crowded expressway. I ran over a piece of steel that punctured the sidewall, so it was a sudden, complete loss of air. I was in the middle lane, with cars all around me. I heard the blowout and could feel a very slight tug in the steering wheel. The warning came on the dash. But the car was totally controllable, and I was able to proceed to the dealer for a fix.
When it came time to replace the itres, I went with the Firestone runflats, and am quite happy. I was considering the KD-W's or some other non-runflat tire, but after the blowout, I would never run anything except runflats.
I do not need new tires on my car yet but was thinking the same thoughts as you. What I decided was that I would go with runflats again, just might purchase a different brand. The reason? With no jack or spare tire, how could you move the car or get to a repair shop if you suddenly find yourself with a flat - either blowout or coming upon your car in a parking lot or at home?
I got tired of $1900 price tag for Goodyear supercar tires for my z51 C6, so I went for the Firestone firehawk RFT. There a great tire. They ride smooth no road noise. They handle just as good as the goodyears. There even a little wider in back even though there the same size as the goodyears. As for traction, well with 525rwhp I really couldn't tell you, but for high speed stability there right there. Oh BTW they were $1034 out the door. No issues!!
Former Vendor
gently letting off the gas and not overreacting will save you with a blow out. 99% of the cars on the road don't have runflats and, aside from Ford Exploders, they aren't all crashing.
If you track the car, I run Falken GR2s for the track, but I think they have been superseded. The KDWs would be good too, but runflats and road courses really don't mix.
I had a blowout in my mom's Datsun when I was in College 20 years ago, but other than that, I've never had a flat that left me completely stranded. I run PS2s for the street, and am very happy with them. If I get stuck one day, then I will call 1-800-CHEV-USA.
Ya I buy my rubber off tire rack but still haven't decided between the KD-W's and runflats, I only track the C6 a couple of times per year so it boils down to safety or better traction the few days I need it.
yes, you're right. but on I355 here in Illinois, the traffic moves at 80 mph almost like a NASCAR restrictor plate draft. If you suddenly lift, or brake, there is a chance of a rear ender. Also, here in Illinois, land of two seasons - winter and road repair - the wet/slush/snow is also a factor. I agree with you. Good driving always helps. As an EMT, I have seen my share of bad results on the road. As a past SCCA division champ, I have had my share of high speed driving. As a pilot, I like to have all the safety backups I can get. Mix the three, and runflats are the answer. IMHO But that's why they make both. Whatever you decide, drive safe and happy
and emsguy has experienced this . This should be enough to convince just about anyone for on-highway driving.
