TPMS and Fix-a-Flat?
Old Oct 15, 2007 | 04:03 PM
thx007's Avatar
thx007
Default TPMS and Fix-a-Flat?
I'm still working on new SC run-flat rubber... but will probably go with a non-runflat in the future. Does anyone have ACTUAL experience with using cans of Fix-a-Flat with the C6, especially any concerns with the TPMS monitor (does it mess things up)?
Obviously, it would only be used in an emergency if another option isn't available.
Old Oct 15, 2007 | 05:03 PM
Chevelle71's Avatar
Chevelle71
You can use fix-flat in an emergency situation. Soon after I purcahsed my car i had a flat on a long trip and had no choice but to use it. i was worried that i had ruined the pressure sensors and maybe the tire..but after taking it to the tire shop they cleaned it all out for me and all was good. They said most of the time they can clean the sensors and they still work however it does make a big mess in the tire and some shops may not want to fool with it. But it is good to know that fixa-flat will not compleltey destroy anything.
Old Oct 16, 2007 | 09:35 AM
calemasters's Avatar
calemasters
TPMS is now standard on all 2008 vehicles, and certain vehicles come with no spare (such as certain 2008 CTS models). Instead, these vehicles come with an inflator with tire sealant. The sealant does not affect the tire pressor sensors.
Old Oct 16, 2007 | 10:07 AM
DUMAN's Avatar
DUMAN
St. Jude Donor '10
does GM sell a kit?
Gene we need a package deal on this stuff.
Old Oct 16, 2007 | 02:58 PM
Buffy's Avatar
Buffy
Tire Rack sells the Conti Comfort Kit, which is about the same difference - compressor with sealant cartridge. Its designed for use with TPMS and should cause no permanent damage to the sensors. About $75-80 as I recall, and a replacement sealant cartridge is $25. The sealant has a shelf life of four years or is good for a single use.
Old Oct 17, 2007 | 01:06 AM
calemasters
Originally Posted by DUMAN
does GM sell a kit?
If you get the no spare tire option (CTS, Solstice, last years Grand Prix,etc.) you get the "inflator kit" in place of the spare. The kit should also be available through the dealer parts department.
Old Oct 17, 2007 | 11:36 AM
FloydSummerOf68's Avatar
FloydSummerOf68
Bummer they didnt give those out with the corvettes then
Old Oct 17, 2007 | 11:58 AM
calemasters
No need to have an inflator kit with runflats. The cars that have the inflator kit do not have run flats. It is one or the other, if the car does not have a spare.
Old Oct 17, 2007 | 12:29 PM
DUMAN's Avatar
DUMAN
St. Jude Donor '10
why? i got a flat about an hour and 1/2 from home and the goodyear dealer would not fix it and did not have a tire to sell me. i ended up a some ratty azz tire shop having them patch it. since goodyear wouldn't. now if i had the inflator kit i would have been set hell even a can of fix a flat.
Old Oct 20, 2007 | 06:53 AM
shockwaveharry's Avatar
shockwaveharry
Sealant is a sensor killer, no doubt about it. I installed non run flats that apparently came with nail magnets for the rears... Killed one completely (xx on the display) and the other became grossly inaccurate.
I traded the goo-cans for a plug kit and mini compressor.
Old Oct 20, 2007 | 08:34 AM
naschmitz's Avatar
naschmitz
I do not understand runflats at all. I took a runflat that I bought from another forum member which had a nail in it to a Goodyear dealer only to be told that the nearest Goodyear dealer that was runflat certified was 30 miles away. And this is near BOSTON, not some out of the way place. Had that been an actual emergency, what good is the runflat? I had to go back home, go to the Goodyear web site, and find a location that was "runflat certified" and then they fixed it cheaply and quickly.
Non-runflats with the Continental ComfortKit are the way to go. Even if the sensor is damaged, a replacement is only $47 from fourm parts vendors. And you can drive farther than 50 miles because the tire has AIR in it.
To TPMS and Fix-a-Flat?
