headlights
Old Oct 17, 2007 | 05:47 PM
dmarano66's Avatar
dmarano66
4th Gear
Default headlights
I am a new corvette owner. I bought a 2005 coupe. Obviously used. As luck would have it one of my passenger side bulbs is out. I opened the hood and it doesn't look that easy to change the bulbs. I called my local dealership and they said it is better for them to change it. Any thoughts. Is it easy? Can someone point me in the right direction to open up and change the bulb?
Thanks.
Don
Old Oct 17, 2007 | 05:53 PM
emsguy's Avatar
emsguy
I think that you change it from the rear through the wheel well. you have to take off the fromt cover of the wheel well.
I think the owner's manual has some info on this as well.
good luck
Old Oct 17, 2007 | 06:30 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
Turn the steering, remove the black rubber/plastic.. install the bulb!
Old Nov 8, 2007 | 12:23 PM
BobST1100's Avatar
BobST1100
Old Nov 8, 2007 | 01:56 PM
asian-winkie's Avatar
asian-winkie
don't get anything on the bulb, use a paper towel to handle.
Old Nov 8, 2007 | 02:39 PM
HAIL THI$'s Avatar
HAIL THI$
This is KEY!
Of course the dealership wants you to bring it in. All they see is $$$. Make sure you get the right bulb and and handle with care.
Old Nov 9, 2007 | 06:49 PM
Oldvetter's Avatar
Oldvetter
I wear disposable vinyl gloves when replacing bulbs. The oil from your hands can shorten life of bulbs.
Old Nov 10, 2007 | 11:55 AM
From C6ZO62C8's Avatar
From C6ZO62C8
I use latex gloves
Old Nov 11, 2007 | 09:43 PM
Bludog's Avatar
Bludog
How easy is it to change the fog lamp bulbs?
To headlights
