Wheel stud help !!!
Old Oct 17, 2007 | 06:08 PM
glencar's Avatar
glencar
Default Wheel stud help !!!
I stripped a wheel stud on the back. I now know it is difficult to replace them without removing most of the rear. Does anyone know what size die to get to try and retread them without replacing them.
Old Oct 17, 2007 | 08:31 PM
GM2433's Avatar
GM2433
Navigator
I would not try to fix it, Just replace the stud, would not trust it to always stay tight if you try and repair the treads
Old Oct 17, 2007 | 10:19 PM
petefias's Avatar
petefias
Listen to the man, good advice!
Old Oct 17, 2007 | 10:43 PM
saplumr's Avatar
saplumr
If you stripped the threads, a die won't do you any good. You'll more than likely have to remove the stud with a hydraulic press and replace it.
Old Oct 17, 2007 | 10:50 PM
runutzzzzz's Avatar
runutzzzzz
If only a few of the first treads are stripped I think you'd be o.k. to re-thread it.
You can also get the stud out with a air-hammer.
To Wheel stud help !!!
