Hank, Our 1-3/4" round port flanges are identical to yours. Both L92 heads we tried them on had a mildly CNC'd exhaust port and the 1-3/4 flange without the tube was conflicting exhaust flow. With the tube matter were worse. This led us to developing a new flange that not only follows the contour of the stock port perfectly but also allows porting without any interference. When I gain access to another L92 head I'll illustrate this in photo's.
Nick
Hi Nick,
Thanks for the clarification but your flanges must not be the same as ours. We still have .016" on a side to port the exhaust until we reach the tube.
Just please be careful when making statements like
"Brasil, Because we took the time to check." Implying other header manufactures do not.
Hank, Fair enough but without getting into details it sounds like the I.D. of our 1-3/4" flanges are significantly different. Also we felt the L92 needed more than a round port. We all do what we feel works best for our customers.
Nick
Good Stuff Nick, thanks.
Just making sure our customers know we are not blocking any flow.
If you guys will be out at SEMA please stop by our booth. #23551
I also wanted to show this in pictures. I had katech send me a trace copy of a mildly ported L92 cylinder head even with the port work there is no obscruction what so ever. Notice the white around the inner black shade of the exhaust port is over 50 thousands thick at the most narrow point and that is on a mild ported cylinder head. The silver ring beyond that is a piece of 1 3/4 S/S tubing.So as for an obstruction I cant see it possible. As for the shape of the flange at stock specs we tested a round exhaust port verses the d port on a flow bench and recored no difference in scavaging.
I ran 1 7/8" Dynatechs and the three inch all the way back on Joel's car....
I have them in stock if you want them shipped....$1895 plus shipping. Headers, three inch pipes all the way back, high flow cats, all gaskets and hardware.
Very nice numbers, especially considering the minor mods. It's insane how well these cars react to subtle changes. One question, since I'm new and stupid . What's torco?
Here's a couple of quick photo's with our standard 1-3/4" flange which clearly indicates that with a tube there's an obstruction. With a larger round port flange the obstuction goes away.
Be that as it may we preferred to redesign the flange to follow the contour of the port. We did the same for the LS7 port.
Hank Daniecki from SLP Performance Parts here. Your statement about the L92 requiring a special flange specific to the port to keep if from being blocked is not correct for 1-3/4" headers. Please see attached photos. This same SLP flange is used on LS2 and L92 SLP 1-3/4" Headers. Please see attached photos of only the flange bolted to the head (L92) and photos of a 1-3/4" header primary welded in place bolted to the head (L92). You can see by the photos there is room for tubing thickness (.056" thk SLP primaries and welds) on the ID of the standard round flange on an L92 head. You can see on the photos attached when the tube is welded in place there is not blockage of the exhaust port on a L92 head using a standard SLP round port flange.
This is why most manufactures are using the same header for LS2 and LS3 C6 applications as the envelope is the same.
Also please view the attached links to the testing and videos SLP has completed on the LS3 C6.
Props to you too. My kooks are going on! In few hours!
Torco makes Race fuel for the top dragsters, and sponsers some of the biggest names at the NHRA Nationals! They have also come out with a "Race Fuel Concetrate" It allows the 91 or 93 to act as higher octane would, when mixed in the tank.
This dyno gragh was done with 12 gallons of 91 mixed with one quart of Torco. This would yield about a 95+ octane mix.
