Hood light
Old Oct 18, 2007 | 11:57 PM
3 Z06ZR1's Avatar
3 Z06ZR1
Default Hood light
Added the GM under hoodlight. 32.00 from Gene Culley.
easy install!
Old Oct 19, 2007 | 12:24 PM
Sativa's Avatar
Sativa
I was thinking about doing this as well.
Where do you hook up the wiring?
Old Oct 19, 2007 | 12:44 PM
mneblett's Avatar
mneblett
Cruise-In VIII Veteran
easy install!
Did you have to cut the hood liner to install it?
Old Oct 19, 2007 | 12:57 PM
SLAZ06's Avatar
SLAZ06
How about a step by step guide?
Old Oct 19, 2007 | 01:14 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
When I added it, there was a connection on the front of the engine bay with a dummy plug in it. I mounted the light and removed the dummy plug simply plugged in the light to the connector. Took a few minutes. Totally easy.
Old Oct 19, 2007 | 01:21 PM
FIRE CAT's Avatar
FIRE CAT
Default Hood Lamp
What turns the Lamp on and off ?
Old Oct 19, 2007 | 01:22 PM
eboggs_jkvl
Moderator emeritus
Mercury switch in the light unit.
Old Oct 19, 2007 | 01:25 PM
DaveC6's Avatar
DaveC6
I put one on an '07. The car is pre-wired, the plug is on the radiator shroud passenger side. I cut a small hole in the hood liner, maybe 1"x2". It calls for a rivit gun which I had. The holes are already in the hood and needs two rivits (or you can probably use small screws). Instructions say to take the whole hood liner off. Don't, you only need to take a few of the plastic plugs off the top right corner.
Old Oct 19, 2007 | 07:14 PM
3 Z06ZR1's Avatar
3 Z06ZR1
I just cut a slit and ran the wires through. Mounted on top of the hood liner!
To Hood light
