How much HP can a LS2 handle
Old Oct 20, 2007 | 03:21 PM
gottiman's Avatar
gottiman
Default How much HP can a LS2 handle
How much RWHP can a LS2 motor handle?
MY G5x3 caM is going to PUT ME over 400 to the wheels, and I have a brand new motor. Does anyone have a big cam setup and some miles on their cars?
Old Oct 20, 2007 | 03:31 PM
not08crmanymore's Avatar
not08crmanymore
You're good in an LS2 till at least 500 + to the wheels I believe.
Old Oct 20, 2007 | 03:50 PM
gottiman's Avatar
gottiman
are the LS2 much stronger then the LS1?
500+ to the wheels cool!!!
Old Oct 20, 2007 | 03:53 PM
not08crmanymore
I don't remember the details of the LS2 but I'm sure it's a little better than the LS1!DON'T WORRY,LOTS OF FOLKS WILL CHIME IN with their info and numbers!
Old Oct 20, 2007 | 04:29 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
The motor will not be the weak point that you need to worry about. With cam work to 400hp I would bet that you should be fine.
Old Oct 20, 2007 | 05:16 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
The bottom end should be good to 550 -600. Several here are in excess of 550 w/TT or SC.
Weak links:
#1. OEM Valve Springs
#2. 2005 Rears
Old Oct 20, 2007 | 06:32 PM
gottiman's Avatar
gottiman
ok, i have patriot performance stage 2 ls6 heads with their springs, and a Zo6 3.42 rear differential.
With the injectors/headers, etc I will actually be 440 RWHP or so.
Are these springs and rear end ok? or are they still the weak links?
Old Oct 20, 2007 | 08:30 PM
BlakShark's Avatar
BlakShark
Dont worry bro.. your good I got the same cam and I could tell you that I've had a smile since i got it installed. Go for it.. Next jump is 500 +
Old Oct 20, 2007 | 10:53 PM
rocket1's Avatar
rocket1
I have 437 RWHP absolutely no problems.
Old Oct 21, 2007 | 01:19 AM
07MontRedcp's Avatar
07MontRedcp
A better question is "How much can the tires handle?".
BJK
Old Oct 21, 2007 | 01:29 AM
OregonC6's Avatar
OregonC6
Answer: The exact HP that it came with from the factory....if you want a warranty on it that is.
Old Oct 21, 2007 | 09:04 AM
runutzzzzz's Avatar
runutzzzzz
Weak links:
#2. 2005 Rears
05 with 574.
Old Oct 21, 2007 | 01:58 PM
gottiman's Avatar
gottiman
how many miles do you guys have on your (CARS) setups?
Old Oct 21, 2007 | 02:17 PM
BrooklynC6's Avatar
BrooklynC6
aka allbottle¬hrottle
From: Brooklyn New York The DVL and the chicken sleep with the fishes....
St. Jude Donor '08
Got 6k hard driven miles on my Procharged LS2 ( 550+ rwhp) so far nothing worse than almost bald tires ......
Old Oct 21, 2007 | 02:20 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
You........ you ..............severe tire abuser you .......................
Old Oct 21, 2007 | 03:21 PM
TTRotary's Avatar
TTRotary
Also depends on the power adder used. H&C is obviously the least stressful, while N2O is going to be the toughest. 500RWHP should not be a problem with H&C, but 500RWHP with nitrous you will probably break something. Lots of FI cars with 550RW and up running fine. Longevity has a lot to do with the install as well. A bad FI install will kill a motor quickly.
Old Oct 21, 2007 | 04:28 PM
KMK454's Avatar
KMK454
How reliable of a DD would a G5x3 cam with an underdrive pulley, LG LT Headers, and an intake be?
To How much HP can a LS2 handle
Old Oct 21, 2007 | 05:32 PM
TTRotary's Avatar
TTRotary
Should be no less reliable than a stocker. Drivability is another matter. I have a 224/228 114 cam and would not want more cam than that for daily driving in traffic. Everyone has a different level of tolerance in that area.
Old Oct 21, 2007 | 11:28 PM
gottiman's Avatar
gottiman
cool. I just don't want any problems with my $10,000 setup for at least a few years.
I dropped a LS2 in my C5
Old Oct 21, 2007 | 11:47 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
