Ported Tb And Heads?
Old Oct 20, 2007 | 06:50 PM
Scotty C6's Avatar
Scotty C6
Default Ported Tb And Heads?
I was wondering how much rwhp will heads and a ported tb will give me? my current mods 2xcam,kooks 1 3/4 headers, hi flo cats, x pipe, corsa sports, varram and spacer, ud pully, and a 160 stat. My current rwhp is 430 and my tq is 391. after doing the tb and heads how much rwhp and tq should i be at?
Old Oct 20, 2007 | 07:12 PM
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
I have almost the exact same setup as you only with the ported TB. I dyno'd 415rwhp 380rwtq. I'm slightly lower than you most likely due to my 4.10 gears. The ported TB wont give you much gains 5-8 seems to be the consensus. The real gains will be from the heads. I'd lean more towards porting the intake along with the heads. Depending on your selection you'll probably see between 450-480rwhp. Call Cartek they'll explain their set ups and give you the best advice to meet your goals.
Old Oct 20, 2007 | 07:54 PM
TaylorMade's Avatar
TaylorMade
Ported heads will definitely give you 20 to 30 extra rwhp.
Old Oct 20, 2007 | 08:33 PM
chucky7's Avatar
chucky7
Default ported heads
Does anyone offer an exchange on the ported LS2 heads?
Charlie
Old Oct 20, 2007 | 09:58 PM
Tony B4's Avatar
Tony B4
St. Jude Donor '08
Scotty,
Do you have the graph from cartek with your numbers? Could you post it?
Old Oct 21, 2007 | 10:27 AM
TLewis4095's Avatar
TLewis4095
Charlie
We can do the removal & porting for you, but don't have any already finished in stock...
To Ported Tb And Heads?
