2001 z06 ABS/Traction control problem!!
Old Oct 24, 2007 | 02:14 PM
C5_Roadster's Avatar
C5_Roadster
Default 2001 z06 ABS/Traction control problem!!
i have a 2001 z06 with 5k miles on it. the car is in clawless shape. but since the day i bought it used with 3k miles on it last yr it has had this service abs and traction control system issue that flashes on the dash everytime i drive it. the codes that it pulls are: 1232, 1233, 1248 and 1283. so therefore the acive handling doesnt work. does anyone have a clue what the problem may be. the dealer said its either an abs sensor in the wheel/ hub or a module up by the front bumper that i believe controls the active hadling and they quoted me 1200 dollars to replace that module!!
thanks chad
Old Oct 24, 2007 | 03:06 PM
not08crmanymore's Avatar
not08crmanymore
wrong section.Might be a couple of bad sensors,however.Watch for the # 2 ring flutter in the 01 z06's which will cause your low oil light to come on at some point,too.Known issue in 01's.
