First to fourth
Old Oct 24, 2007 | 04:06 PM
wrecks's Avatar
wrecks
Default First to fourth
just sold my 93 and am buying an 08...does anyone know if they still have that horrible first to four thing going on with the tranny
Old Oct 24, 2007 | 04:12 PM
C6~Missle's Avatar
C6~Missle
Yes.. it's still there.. gets a CAGS defeat resistor plug and no more skip shift
Old Oct 24, 2007 | 05:18 PM
EuroRod's Avatar
EuroRod
It can be completely turned off inside the PCM with the right software.
Old Oct 24, 2007 | 09:46 PM
robvuk's Avatar
robvuk
It can be completely bypassed by not driving like an old lady too.
Old Oct 24, 2007 | 10:15 PM
NIGHTSTALKER's Avatar
NIGHTSTALKER
I waited until I got my Predator Tuner to disable the CAGS, but the $20 harness is just as good
Old Oct 25, 2007 | 12:40 AM
AustinVettes's Avatar
AustinVettes
It has only kicked in three times in the month that I've had the car. The profile is much less intrusive than in the C5's, and it happens so infrequently that I'm not even bothering to install a skip shift eliminator.
Old Oct 25, 2007 | 08:20 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
You might wait and see. I have over 1,800 miles and I've only seen it once. IMHO its no longer really an issue, nothing at all like the C5.
Old Oct 25, 2007 | 10:01 AM
chucky7's Avatar
chucky7
Default 1-4 skip shift
Just pull fuse #10 in under the hood. It only feeds the solinoid for engaging the 1-4 shift. Trust me, that's all it does. Most people who have pulled fuse #10 and had problems think that they pulled fuse #10 but actually pulled the wrong fuse. Here is a picture.
My Chevy mechanic advised me about this fix 2 years ago. I pulled mine then and no troubles in two years. Standing on the passenger side looking at the fuse panel, you are actually looking from top of my diagram down at the Fuse panel.
Charlie
[/IMG]
Old Oct 25, 2007 | 10:09 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Charlie
[/IMG]
I believe this causes a light in my 07. Something was changed and pulling the fuse causes an SES light. The 2 things that will disable CAGS is getting a !CAGS plug and installing it OR having EFILive, HPTuners, Predator equivalent and "tune" it out.
Elmer
Old Oct 25, 2007 | 10:20 AM
6spdC6's Avatar
6spdC6
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
No where as bad a a C5.
I had a 05 and now a 07 and it never gets me, other than the time I made it do it as a check. I had to put a CAG killer on my Camaro and 98 Vert,but its fine on the C6s IMHO.
Old Dec 2, 2007 | 02:36 PM
CJMatthews's Avatar
CJMatthews
3rd Gear
Which is the easiest way to bypass the 1st to 4th feature? Which way DOESNT void the warranty, if any? I just got an 07 convertible and I hate the feature but I don't want to void the warranty.
Old Dec 2, 2007 | 08:24 PM
mitchm11741's Avatar
mitchm11741
Have a tuner modify the computer parameters to turn it off. It is physically completely invisible. While in the computer module, have them give the thing a tune. I have a hard time believing a dealer would bust your shoes about either defeating the 1-4 shift with either hardware or software mods ... that is assuming they would even detect it (I doubt they would even look for this mod). If you are completely freaked out about your warranty, don't do any mods and live with it.
Old Dec 2, 2007 | 09:23 PM
valdeztke's Avatar
valdeztke
Old Dec 4, 2007 | 01:30 PM
CJMatthews's Avatar
CJMatthews
3rd Gear
what about hardware mods?
Old Dec 5, 2007 | 12:02 AM
Big Tex's Avatar
Big Tex
So far I have note experience this in my 08. Most likely because I never shift under 3k as I love the sound of my "Stingers"
Old Dec 6, 2007 | 01:59 PM
rbaker's Avatar
rbaker
8th Gear
Elmer
Removing the #10 fuse disables the CAGS, but it caused a check engine light for me too. I tried this yesterday on my'08 and put the fuse back in today to get rid of the light.
Like some of the other guys say, you can drive around CAGS just by giving it more gas, or holding the gear, etc. It's only activated about 3 times in the month I've owned the car. However, it's usually at the most annoying time, like when I forget about it & get stuck behind some _real_ slow a**es and get bumped into 4th & then have no power. Then it's annoying.
Old Dec 7, 2007 | 10:21 PM
GunKata's Avatar
GunKata
I didn't like the skip shift at first, now I do. Its great in traffic that way and is there for a reason - increased MPGs.
And as some already said, drive it harder/stay longer in gear if you don't want it to skip and you'll be fine.
To First to fourth
Old Dec 13, 2007 | 10:05 PM
tlane62's Avatar
tlane62
Default Cags
Well - you have 2 choices - drive faster or spend the $15 + shipping and get the little harness from Gene to end the prob forever!
Old Dec 14, 2007 | 10:05 PM
Razrback16's Avatar
Razrback16
You can also just shift 1-2 early or late. It only does it between 15-19MPH. I always just shift 1-2 right around 14MPH and it almost never gets me.
Old Dec 14, 2007 | 10:12 PM
Hooked4Life's Avatar
Hooked4Life
Mine kicked in once, and my hair instantly turned blue.
