Rear Dif Fluid Change Frequency?
Old Oct 26, 2007 | 06:21 PM
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
Default Rear Dif Fluid Change Frequency?
How often is it recommended to change the rear dif fluid with aftermarket gears(4.10s)?
Old Oct 26, 2007 | 06:31 PM
C6~Missle's Avatar
C6~Missle
depends on use and fluids used.. I would change out the first fill at 5K miles... then every 30K after that... but that depends on how hard you use your car. I tend to be on the **** side...
Old Oct 26, 2007 | 06:34 PM
Randy in Atlanta's Avatar
Randy in Atlanta
I think once a year with the 410 gears!!!
Randy
Old Oct 26, 2007 | 06:38 PM
UNKNOWN's Avatar
UNKNOWN
Banned Scam/Spammer
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Randy
can't be too safe
To Rear Dif Fluid Change Frequency?
