Why it slower when hotter?????
Old Oct 28, 2007 | 09:03 AM
steve286's Avatar
steve286
Default Why it slower when hotter?????
I have noticed that after my car warms up in the morning and I get on it it is REALLY FAST. I have also noticed that when driving it for an exteded period of time it get slower . I guess I have heard this is called "heat soak." Is there anything I can do to combat this problem or make it not so dramatic, granted I live in Phoenix AZ. Any help would be appreciated
Old Oct 28, 2007 | 09:07 AM
C6~Missle's Avatar
C6~Missle
Air is thicker, more dense when cold.. So you are cramming more air and fuel in the combustion chamber for more power.. As air heats up it becomes less dense and can't support as much power. In simple terms...
Old Oct 28, 2007 | 09:14 AM
Craigster05's Avatar
Craigster05
St. Jude Donor '07-'08-'09-'11-'12
Correct, and as intake air temps increase, after a certain point the computer will pull timing which will also rob you of power.
The best thing you can do to help is install a 160 thermostat and get the engine tuned. Part of the tuning process will turn the fans on sooner and keep your engine running cooler...which in turn keeps your power up.
Actually, if you want to take a short ride, Chuck CoW in in Phoenix this weekend doing tunes, he could help you out. Here is his itinerary:
DATE: Friday October 26, Saturday 27 and Sunday 28th
PLACE: Arizona DynoChip in Chandler
513 54th St. Suite 5
Chandler Arizona 85226
Contact Person: Keith
You can also get Chuck on his cell at 914-332-0049 if you want to, if you cant make it and want to road trip for some fun, he and a bunch of us will be at SEMA in Vegas this week. Chuck will be doing tunes there as well.
Old Oct 28, 2007 | 10:50 AM
toy 4 ray's Avatar
toy 4 ray
I was out for a morning drive and the temperature was in the low 40's. The vette was screaming. If I understand horsepower numbers from a dyno, they are adjusted for temperature, Humidity and barometric pressure. Does anyone know how much more actual horse power you have at say 40 degrees vs 80 degrees outside temperature?
Old Oct 28, 2007 | 11:01 AM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
The difference between 80 deg and 40 deg is very substantial and if i was to guess it would be about 25rwhp. Just ask the guys what happens to their mph and et's at the drag strip with those differences in temp.
Old Oct 28, 2007 | 11:28 AM
Modshack's Avatar
Modshack
Typical power losses. To convert C to F multiply by 1.8 and add 32..
Old Oct 28, 2007 | 01:43 PM
CHASLS2's Avatar
CHASLS2
St. Jude Donor '13
The engine pulls more timing in hotter temps. After i installed a Vararam it really helped, now it feels like i'm driving in winter temps in the summer.
Old Oct 28, 2007 | 06:34 PM
mlongo99's Avatar
mlongo99
Cruise-In VIII Veteran
When you're intake air temp is 100C, you've got bigger problems to worry about!
Old Oct 28, 2007 | 10:28 PM
C6XTACY's Avatar
C6XTACY
meltdown, anyone?
Old Oct 29, 2007 | 05:02 PM
ejbarre's Avatar
ejbarre
Vararam CAI + 160° Thermostat + Chuck CoW Tune.
Old Oct 29, 2007 | 05:29 PM
vette-oholic's Avatar
vette-oholic
i think you want to start that table at -20 deg C.
Old Oct 29, 2007 | 07:29 PM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default Very Good Info!
VERY GOOD INFO...THANKS FOR POSTING THIS...
This is what I've been preaching for years... This week in Arizona, I had a tuner ask me why I was insisting on low temp stats before tuning the cars...
I said..."you don't know....It's soooo damn hot here...Why wouldn't you????"
Anyone who was part of the Latest "Chuck CoW TRAVAL n- TUNE in ARIZONA" could sure tell em why!
KEEP IT COOL!
Chuck CoW
Old Oct 29, 2007 | 10:55 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
While the cold air density has an impact, I believe the primary reason is the IAT sensor (intake air temp) sends a signal to the ECM. The ECM changes ignition timing to help prevent knock. Unfortunately, it pulls out more timing than is really necessary. A tune modifies the IAT tables and is not as aggressive in pulling timing out. This is the real "heat soak" problem people write about.
The solution is to get the ECM tuned. A 160 degree thermostat also helps a little but not nearly as much as a tune.
To Why it slower when hotter?????
