Hot Engine code after Header Install
Old Oct 29, 2007 | 12:55 PM
Isaiah48's Avatar
Isaiah48
Default Hot Engine code after Header Install
I just finished installing 1 7/8" headers this weekend and I immediatley got a HOT ENGINE - AIR CONDITIONING OFF on my display and my Temperature sensor stopped working... I looked all over to see if I might have inadvertently unhooked a sensor but cant seem to find anything.
I cleared the code and it came right back.
I can't seem to identify where the Temprature Sensor even is.
I did break off part of a sensor on the lower side of the 6spd Transmission, the plug still seemed to work though...
Any thoughts?
Old Oct 29, 2007 | 09:27 PM
Modshack's Avatar
Modshack
I was looking around my engine bay today in preparation for my header install....I noticed a sender plugged into the head, just forward of the first cylinder on the left bank. I believe this is the temp sensor and it's close to the exhaust manifold...Check to see if you didn't inadvertantly damage it or break the wires..
Old Oct 29, 2007 | 09:44 PM
mitchm11741's Avatar
mitchm11741
Did you install a 160 t'stat? I am seeing the same thing. So are some others. Check out this thread:
http://forums.corvetteforum.com/show....php?t=1837642
Some folks say this can be taken out by changing a parameter in the tune.
Old Oct 30, 2007 | 12:53 PM
Isaiah48's Avatar
Isaiah48
You called it... I cracked the sending unit clasp and it had inadvertantly came partially unplugged. Thanks for your help!
Old Oct 30, 2007 | 01:53 PM
Modshack's Avatar
Modshack
Excellent....Glad that helped!.....
To Hot Engine code after Header Install
