Need help with Dyno results!!
Old Oct 29, 2007 | 01:55 PM
Purdue's Avatar
Purdue
Default Need help with Dyno results!!
I had my car dynoed last Friday and the Dyno shop had issues with their printer so they had everyone email themselves the results.
I had two pulls with my C6 (tune) and my father had two pulls with his C6 (no tune) and I cannot figure out how to view our results...I give up
The shop used a Dynojet, so is their anybody that would be willing to help me out? I can email the files froms the pulls.
I would greatly appreciate any help
Old Oct 29, 2007 | 02:12 PM
07MontRedcp's Avatar
07MontRedcp
The shop used a Dynojet, so is their anybody that would be willing to help me out? I can email the links to the pulls.
Why don't you cut and paste that link into your post??
BJK
Old Oct 29, 2007 | 02:55 PM
Purdue's Avatar
Purdue
BJK
They are actually files and not links! I will correct my post.
TTT
Old Oct 29, 2007 | 03:28 PM
BLU-BY-U's Avatar
BLU-BY-U
you need to download the Winpep software from dynojets website
http://www.dynojet.com/downloads/software.aspx
you can then "load" up the files they emailed you and you can do all kinds of cool stuff with the graphs.
Old Oct 29, 2007 | 03:53 PM
Purdue's Avatar
Purdue
I did load the software but stll cannot figure out how to set the graphs to see HP/TQ etc...I even followed the tutorial .
Old Oct 31, 2007 | 04:06 PM
Purdue's Avatar
Purdue
There has to be someone that has experience in reading these dyno graphs to determine HP and TQ?
TTT
Old Oct 31, 2007 | 06:09 PM
gtodoug's Avatar
gtodoug
Send it to me @ dcampbelljr@coralspringsautomall.com. I have experience with the software.
dougie
Old Oct 31, 2007 | 11:01 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Doug will help you.
If you want to try yourself...and this is all from memory as I don't have it loaded on this computer....when you load a run from the file finder on the left then right click on the right and left border of the graph, and choose HP on one side and Torque on the other. Then choose engine rpm for your bottom axis. If you like choose a 2 graph setup from the buttons on top then use airfuel as the axis on that.
You can add other runs to your graph if you like by double clicking on them from the file finder on the left.
On the smoothing button on top slide the slider to the right (which is 5) and on the correction choose SAE. Then you can file save as the graph, choose jpg instead of bmp.
With a little bit of right clicking and fooling around with the software I bet you'll get it. I did.
It's actually great software. You can also export the run files and import them into Excel, and do the same with your HP Tuners files, and do some interesting comparisons. I did this to find my MAF error since I don't have a wideband installed in the car so I used the dyno wideband.
Old Nov 1, 2007 | 12:26 AM
glennhl's Avatar
glennhl
Purdue,
It's very frustrating, took some time playing with it to figure it out. When I double click any of my files all that comes up is the power curve. Then I go to the right and right click on the "none" and select "torque." I do the same thing at the bottom and select "engine speed." Then I select A/F ratio for the bottom section.
Good luck,
Glenn
Old Nov 1, 2007 | 12:42 AM
BLU-BY-U's Avatar
BLU-BY-U
andre, I loaded the files and the first run is definitely jacked up, something like peaks of 25hp and 75tq. looks like a malfunction. the second run, if I'm doing this correctly, shows peaks of 422hp and 426tq SAE smoothing 5, and the engine speed is set to gear 3. But the graph is shaped very weird, not a curve at all. looks wrong.
not sure if I'm doing something wrong with the winpep or the runs themselves are screwed by the operator at the shop or his equipment was malfunctioning.
Old Nov 1, 2007 | 12:04 PM
Purdue's Avatar
Purdue
Thanks to all for trying to help .
BLU-BY-U, I agree I think the runs are messed up....I wish my car had 422hp .
They told me I put down 341HP but I can't validate it due to the graphs being out of whack.
To Need help with Dyno results!!
