02 Sensor
Old Nov 6, 2007 | 09:19 AM
tloon's Avatar
tloon
Default 02 Sensor
Do you need a special wrench to remove the 02 sensor? Getting ready for the header install soon.
Old Nov 6, 2007 | 09:49 AM
achilds's Avatar
achilds
Most of the time you do. It is a slotted socket you can get it at most any auto parts place.
Old Nov 6, 2007 | 11:48 AM
SoldSyclone's Avatar
SoldSyclone
NO not when you can get a wrench on them.
But it is big some basic tool sets dont go that big.
Old Nov 6, 2007 | 11:52 AM
sscamaro's Avatar
sscamaro
St. Jude Donor '07
An open end wrench or Crescent wrench will work.
Old Nov 6, 2007 | 11:56 AM
HAIL THI$'s Avatar
HAIL THI$
This will work on all the O2's. The top ones are a little tricky, but you should get it.
Old Nov 6, 2007 | 03:32 PM
8850's Avatar
8850
I ruined one of mine when my end wrench slipped trying to get it out on my 08. It's too deep into the exhaust manifolds for a crescent or end wrench to fit properly. Do it right and get an 02 removing socket!
Old Nov 6, 2007 | 05:19 PM
jdwk's Avatar
jdwk
Autozone rents out their O2 sensor removal kit for free. They put a $17 hold on your credit card till you give it back.
It consists of a deep socket (something like 22mm) that is the standard size of all 02 sensors, and it has a slot down the side of it for the cable to go. There are also two other pieces in the kit, but not sure what you would use them for.
I realized I didn't really need it since I was taking all my pipes out anyway when I did my headers, and a crecent wrench works just fine then, but it still helped.
Old Nov 6, 2007 | 06:42 PM
toro1966's Avatar
toro1966
For 10 bucks, BUY THE SOCKET! A new O2 is $100 if you screw it up. Just my .02
Old Nov 6, 2007 | 06:54 PM
VET4LES's Avatar
VET4LES
Old Nov 6, 2007 | 08:25 PM
Finster07's Avatar
Finster07
Just paid about $10 at Autozone. It is the only way to go...no brainer.
Old Nov 6, 2007 | 10:46 PM
Bludog's Avatar
Bludog
Just installed a set of Kooks last weekend. A regular open end wrench will work. For the O2's on the exhaust manifolds, just remove the heat shields with a 10mm before you remove the O2's
Old Nov 6, 2007 | 11:02 PM
AintQik's Avatar
AintQik
Its 7/8
I have the special tool, as well as a thousand others and usually use a 7/8ths unless it is a really stuck or hard to get to.
Old Nov 7, 2007 | 11:14 AM
tloon's Avatar
tloon
What about replacing the 02 sensor on the new headers and cats? Do you need anti-seize or locktite?
Old Nov 7, 2007 | 12:46 PM
C6~Missle's Avatar
C6~Missle
You need a high temp anti-seize for the O2 sensor..
Old Nov 7, 2007 | 03:51 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
Old Nov 7, 2007 | 06:27 PM
Bludog's Avatar
Bludog
Definately use high temp anti sieze for the O2 sensor and make sure you do not get it on the sensor ( you will ruin it ) Also use anti sieze on all your bolts that go into the block.
To 02 Sensor
