is 210 to hot
Old Nov 6, 2007 | 12:46 PM
DUMAN's Avatar
DUMAN
St. Jude Donor '10
Default is 210 to hot
my car runs at 210 degrees even when it 60 degrees out side. it does cool a bit when i am a hiway speed. is this right??
Old Nov 6, 2007 | 12:47 PM
FloydSummerOf68's Avatar
FloydSummerOf68
That's a little on the warm side, but nothing I would worry about.
Mine runs about 195 driving around and 205-210 in stop and go.
dennis50nj's Avatar
dennis50nj
thats where they run
Old Nov 6, 2007 | 12:49 PM
FloydSummerOf68
I've never seen 210 steadily...ever.
Only on hot days in traffic do I see over 200.
Old Nov 6, 2007 | 01:10 PM
Modshack's Avatar
Modshack
My '08 would stabilize at 198-200
160 degree stat and no fan tuning (Yet) and it's at 183-185
HAIL THI$'s Avatar
HAIL THI$
Every car is different. Do you have a lot mods? Mine runs right over 200 running around town. Get into traffic or go to the track it stays right on 210. If you're real worried about it mybe you should invest in a T160 and have it installed. That way the fans come on sooner.
Old Nov 6, 2007 | 01:18 PM
DUMAN's Avatar
DUMAN
St. Jude Donor '10
it has a diablo tuner, cat backs and a vararam. i the summer it runs 220 at speeds of 70 plus.
Old Nov 6, 2007 | 01:20 PM
knkali's Avatar
knkali
mine is like the op #s
Old Nov 6, 2007 | 01:42 PM
LS3 Machine's Avatar
LS3 Machine
St. Jude Donor '11
The thermostat has nothing to do with when the fans come on, it is in the programming of the ECU. The 160 stat will actually delay the need for the fans to kick in a bit.
Old Nov 6, 2007 | 04:53 PM
3 Z06ZR1's Avatar
3 Z06ZR1
Oil or coolant!
Old Nov 6, 2007 | 05:53 PM
Razrback16's Avatar
Razrback16
Mine runs right around 207 consistently. When I start modding I will have (and would recommend) putting in a 160 and having the fans tuned to keep the operating temp around 180 or so.
Old Nov 6, 2007 | 07:11 PM
C6~Missle's Avatar
C6~Missle
i run 190 - 192 with stock stat. It only gets up to 210 or so when in stop and go... make sure you don't have anything blocking the radiator from the bottom... you sometimes suck up paper bags and such which can block airflow
Old Nov 6, 2007 | 07:59 PM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
Originally Posted by Rock'n Blue 08
Oil or coolant!
Old Nov 6, 2007 | 08:27 PM
DUMAN's Avatar
DUMAN
St. Jude Donor '10
COOLANT
Old Nov 6, 2007 | 10:03 PM
1bdasvt's Avatar
1bdasvt
St. Jude Donor '06-'09
Mine runs at 180 on the freeway!{160 stat}
Old Nov 6, 2007 | 10:17 PM
4evervette's Avatar
4evervette
over here ..i seen 230 once ..but after the 160 stat....max i have seen 195 after alittle abuse
Old Nov 7, 2007 | 08:14 AM
FloydSummerOf68
For comparison....
Today was 60 degrees on the nose going to work.
In 20 minutes of stopped traffic (sigh) it went up to 216.
As soon as I got out of the traffic and back to moving on the freeway it jumped down to 190 and settled at 194 for the rest of the ride.
So if yours is running 210 while driving in 60 degree weather it is running abotu 15 degrees hotter than mine.
Stock thermo and stock fan tune.
To is 210 to hot
