Tire ran-flat
Tire ran-flat
My C6 indicated tire pressure low so I tried to add air but my run-flat wouldn't take any and now it indicates a flat tire, probably a slow leak but why wouldn't it take air, valve problem maybe and do I have to fix the run-flat immediately? Maybe it can be plugged but I don't want to buy another run-flat from the dealership as I need new tires soon anyways, advice please.
I noticed on one of my tires once that I had to press down really hard with the air hose to engage the tire valve. I picked up a nail and was able to put air in it and drive it to Discount Tires. They removed and patched the tire. You can drive it flat 50 mph for 100 miles. They repaired it for free but I've heard that some are charging as high as $60-75 to repair a run flat.........
Can I let the airless run-flat sit for awhile in my garage or will it damage the rim? It doesn't look flat at all so I assume I can let it sit till I install new tires since it can be driven anyways?
yes they are hard to add air too, certain air chucks work better than others
Stealership charged me 50 bucks to repair a run-flat on my Z51.
Wasn't happy, but some tire places are not cool with patching/plugging ANY performance tire, especially the RFs.
I'm replacing the GY's with Kumhos, when they wear out, fwiw - run-flat my ***.
Try removing the valve core and overinflating- that way, when you put the core back in (while air is rushing out), you can just bleed down to where you need to be.
Regardless of how the tire may look, and I dont' have experience with the RF's, letting it sit with no pressure/low pressure may result in a flat spot, which will rattle your teeth loose until you've driven a few miles.
I'd get it aired up asap, personally.
Good luck with it.
Good luck with it.
