An Axle Nut Report
Old Nov 12, 2007 | 08:19 AM
GOLD72's Avatar
GOLD72
Default An Axle Nut Report
I bought a 34mm-6 point 1/2" drive impact socket labeled for "GM Axles" last Friday. Checked both of my cars by starting at 60 ft-lbs and increasing in 10 ft-lbs increments. The 06Z06 has nearly 20k miles. The LR made it to 120 ft-lbs without moving. The RR moved slightly at 120. Within production tolerances, I feel like this car definitely does not exhibit the loose axle nut syndrone widely reported here. The 07 vert is a garage queen with almost 2500 miles. Both nuts never moved right up to the factory spec 120 ft-lbs.
