409 ls2?
Old Nov 15, 2007 | 11:55 AM
edcmat-l1's Avatar
edcmat-l1
Originally Posted by andreas g.
You're chasing your tail looking for that special crank to yield you the desired 409 ci. First I don't think you can bore the LS2 to 4.068 dia. There sleves don't have enough thickness. The standard approch before the LS3 block (L92) was to stroke the LS2 with a 4.00 crank for 402 inches. On the other hand, I took an LS3 block and stroked it with a 4.100 crank for a total displacment of 427 ci. Question, why are you stuck on having a 409 ci ????. Secondly, do you have any idea of how much $ a custom crank would be to yield you the 409 inches???.
Exactly. Thats why I asked if he were stuck on the 409.
Old Nov 15, 2007 | 12:52 PM
Shrike6's Avatar
Shrike6
Somba master
Cruise-In 7, 9 & 12 Veteran
Wounded Warrior Escort '11
St. Jude Donor '07-'08-'09-'10-'11
Guys, this is a thought experiment of mine. I've heard about 402, 408, 412, 416, 427 possibilities.
I know new Darton liners could be bored to over 4.10 or so, and with the 4.00"stroker crank, I can get 427ci. That's a well known quantity.
But, since my knowlege of engine building is just north of zero, I thought maybe I'd see if a 409 was doable. With you guys' input I'm seeing how this is an orange zebra.
I get lots of stupid ideas, every once in awhile one ain't so stupid.
Lots of 427 'C6 'vettes out there now, and they're great. The sound of a 409 'vette is cool, though. Especially when you have no idea what it would take to get there.
Again, thanks for the information!
GM
Old Nov 15, 2007 | 01:28 PM
Kevinmatt's Avatar
Kevinmatt
St. Jude Donor '11
I guess the real issue is what is the most economical approach if you own a LS2 and are interested in stroking it. I recently had a tuner tell me the LS3 block would only go out 416 and that was close enough to 427. I'm not sure if he did not know it would go to 427 or it was more econimical to go out only to 416.
I would also be curious to know how much of the LS2 engine could be used on a stroker project. It's obvious if you select the LS3 block path to a stroker, the block is not usable LOL. I wonder if the FAST Intake Manifold I have on my LS2 would work on the LS3 stroker. Will the Kooks headers still fit the LS3 stroker. I'm pretty sure I would have to buy new heads since I am running stock LS2 heads right now. I do have a 228/232 @112 LSA cam. I wonder if I could reuse the cam in a LS3 stroker? I would expect my Callaway Honker CAI and UD Pulley would also be usable on a LS3 stroker project??
I just modded my LS2, but I am thinking about the next mod already. Reading all the post, it appears that stroking the LS3 or LS2 is the most economical approach to boosting the lower end torque. That's the area where my car suffers the most right now. If I had it to do over again, I would have probably stroked the engine from the get go!
I have $4100 tied up in my current engine mods (Parts only). I wonder how much of the parts could be used on a stroker project?
Maybe next time I will drive that extra 1 1/2 hour or so and come see Ed about a 427 stroker project. It sounds like he knows what he is talking about.
Old Nov 15, 2007 | 03:00 PM
andreas g.'s Avatar
andreas g.
You're right, an LS3 goes to 416 with a 4.00 inch crank, but makes 427 ci with a 4.100 crank. That's what I did. With an LS2 I would simply use a 4 inch stroke , have a 402 and be done with it. I agree that would be the most economical way to go, like you said.
Old Nov 15, 2007 | 03:30 PM
edcmat-l1's Avatar
edcmat-l1
The headers would fit. The cam is pretty small for a 400+ cube motor. And you would def want to step up the heads. With an engine that size, everything should be bigger to support the airflow requirements.
You FAST 90 would work.
Aftermarket heads would be your best bet. Or 4 in bore LS7s, or L92s, the last two requiring a new intake, which would mean you would have to give up your FAST.
PS, I too would recommend just stoking your motor. Much more economical that way.
Old Nov 15, 2007 | 06:55 PM
TTRotary's Avatar
TTRotary
Originally Posted by edcmat-l1
With slightly lower compression, you have more room to tune aggressively. And for the most part you can tune around the SLIGHTLY LOWER compression. And the IATs dont exactly skyrocket. got a couple maggie graphs for ya.
First one is a 6.0, stock compression, 8.5 lbs of boost. Limited amount of timing. Now, I tune with a 5 gas, monitoring NOX, so I know when we're getting pretty hot, as far as combustion temps. Because of the comp, and the hypereutectic pistons, I'm limited to how aggressive I can tune this thing. Still pretty respectable #s.
This one, is a 6.0 with 9.5 comp, so almost a full point lower. higher boost, peaks at 12.3. Forged pistons. More aggressive tune.
Comparing the two, instead of just looking at the peak numbers, look at the torque at 2500, and the tq and hp curves. The second graph has a much broader curve, due to higher boost combined with a more aggressive tune, all in conjunction with lower compression. Again, almost a full point.
Interesting results. There is more flexibility here than I thought. I love it when tuners do this type of analysis. Thanks for sharing.
Old Nov 15, 2007 | 09:26 PM
SpinMonster's Avatar
SpinMonster
Sorry for the hijack again Gary.
To both you guys, I understand the limited displacement of a maggie. I'm not talking abourt running 8.5 or 9 to one. With slightly lower compression, you have more room to tune aggressively. And for the most part you can tune around the SLIGHTLY LOWER compression. And the IATs dont exactly skyrocket. got a couple maggie graphs for ya.
This one, is a 6.0 with 9.5 comp, so almost a full point lower. higher boost, peaks at 12.3. Forged pistons. More aggressive tune. The HP fall off is due to either belt slip, or loss of efficiency, we'll find out Monday.
My point being that with slightly lower compression, you are afforded the benefit of being able to be more aggressive with the tune.
Both cars were 112s. With a larger motor, of course you'd wanna run a 122. So, even with a maggie, you can benefit from dropping the comp some. I wouldnt have dropped this on to 9.5, but the results werent bad. The mad torque numbers are due to primarily being able to tune it more aggressively in that range. Even with the increased boost, the IATs arent much over that of a normal boost app. The start to climb @ idle, but all of them do. When you crack the throttle, even just a little, they come right back down instantly.
This is as close as I could come to an apples to apples comparison. If the boost were exactly the same in both cases, only dif being compression, I'm sure the power dif would be closer, but still, the lower comp engine could most likely be tuned to more than make up for the lower compression, negating any benefit of running higher comp.
Actually its 1.4 lower than stock at 9.5 but I'm sold on what you are saying. One thing no one would argue is that why run the compression with that insane level of low end TQ? If anyone has felt 30 or so increase at 4k rpm's I have no comprehension of what 500rwtq feelslike at 2.5k rpms. Makes me think its the best all around period. I couldn't imagine getting that to the ground so even if you werent tuning aggressively, it would make sense.
People arent so willing to lower compression as I am. With the stock gaskets on the L92's and a 6 liter displacement, I would end up at or near 10.4:1 at best. The use of the mag on a stock motor is appealing to people that dont want to touch an otherwise stock motor. I would do what the install calls for.
Any word on when the LS3 mag is going to hit the public?
Thansk for sharing Ed.
Old Nov 15, 2007 | 09:32 PM
SpinMonster
Comp stated they had the L92 completed and were testing its gains on the dyno while they were at SEMA. They claimed a year end release. Hopefully, it will end the L92 head vs. cathedral port head debate. Having seen the gains going to a ported L76 manifold for the L92 heads on my car I am sure it will better the performance at least as well as the old FAST did for cathedral heads.
Old Nov 15, 2007 | 10:13 PM
edcmat-l1's Avatar
edcmat-l1
There I go again, showin off my math skills!!
I dont know what I was thinkin. As for what that thing feels like, it'll rip your head off just blippin the throttle. Its tuned 2 bar SD, and the throttle response is BRUTAL.
As for tuning it, the timing table is pretty close to what a high compression H/C package would be, with ZERO KR, very low NOX PPM, and no meth. The owner is installing a meth kit this weekend.
Should have new numbers for it Monday.
I have no clue about the release of the LS3 maggie.
Old Nov 15, 2007 | 10:36 PM
edcmat-l1's Avatar
edcmat-l1
BTW, Gary, back to the original subject, you can have a custom crank ground, all it takes is $$.
You should be able to get one done for 1500 bucks or so.
Custom pistons, with the pins in the right location to be able to use an off the shelf rod, approx 800.
Being able to say you gotta 409 Vette, PRICELESS.
Old Nov 15, 2007 | 10:50 PM
Shrike6's Avatar
Shrike6
Somba master
See guys, this why Ed has the rep he does! Not only does he know his stuff, but he's always thinkin'! I bet he could even make my screwball idea work.
So, lessee now...
LS3 block, custom crank or pistons, my current l92 heads, l76 intake, throttle body, accessories, headers etc used wherever possible to conserve cash. A final bitchin' tune. $?
GM
Shoot Ed, we could be famous!
Old Nov 16, 2007 | 08:37 AM
edcmat-l1's Avatar
edcmat-l1
Or infamous!! LOL
Old Nov 16, 2007 | 11:53 AM
  #33
Shrike6's Avatar
Shrike6
Somba master
Should be no problem if we left off the flux capacitor.
GM
Old Nov 16, 2007 | 12:24 PM
  #34
RWSjr's Avatar
RWSjr
GM
No, leave that in. - you may need to get there yesterday.
