brakes
Old Nov 15, 2007 | 12:14 AM
waterboy1966's Avatar
waterboy1966
Default brakes
is it possible to put the same brakes on the back of my 2008 vette that r in the front. will this make a better difference in braking.
Old Nov 15, 2007 | 12:16 AM
User 81424's Avatar
User 81424
Yes, but you will lose your emergency brake, and no it will not make a difference.
Old Nov 15, 2007 | 12:18 AM
huskeric's Avatar
huskeric
Nope. The fronts are completely different - the calipers, rotors, pads, etc are all larger. If you want to increase your braking capacity, consider upgrading to a complete Z06 system - front and rear.
Old Nov 15, 2007 | 01:01 AM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Even if you could you'd affect the brake bias between the front and back.
San
Old Nov 15, 2007 | 01:21 AM
User 81424's Avatar
User 81424
San
It was possible on the C5, most did it for looks, some track day types did it because the rear rotor was so thin. No one did it for performance, technically it will decrease brake performance as it adds weight.
To brakes
