Blown Bose Amp...
Old Nov 15, 2007 | 02:24 PM
Isaiah48's Avatar
Isaiah48
Default Blown Bose Amp...
Due to unfortunatle and incredibly stupid mistake, I believe I blew the Bose Amp in my factory setup. It was dark and I inadvertantly hooked up a Jump Pac backwards
My question is does anyone know exactly how to confirm the amp is blown or is there a fuse in some remote place for it? I looked under the passenger floor mat and under the hood and really couldn't identify the fuse that would go to it. I checked just about every fuse in the car anyway, but to no avail...
Also does anyone know how the message tones/beeps for things like the presets tie into the system? They also stopped working...
If it's bad, I wonder if I can upgrade the amp instead of replacing it with the small Bose...
BTW. My head unit seems to be working, it just doesn't produce any sound...
Thanks!
Old Nov 15, 2007 | 02:47 PM
vette-oholic's Avatar
vette-oholic
Most amps I have dealt with have the fuses accessible right through the amp enclosure... but i havent worked with OEM direct to vendor type of amps like these probably are... so not really sure...
If i were you. I would take it to the dealer and have them replace it. Dont tell them what you did and they will likely never know.
Old Nov 15, 2007 | 03:13 PM
Isaiah48's Avatar
Isaiah48
It's out of warranty already...
Old Nov 15, 2007 | 04:00 PM
Miaugi's Avatar
Miaugi
The tones and chimes are produced by the amp. For answers about checking or verifying the amp try posting in the Audio section.
Old Nov 15, 2007 | 05:11 PM
calemasters's Avatar
calemasters
Thanks!
First check the 30 amp Fuse #31 in the underhood fuse block.
If OK, check the 15 amp Radio/S-Band/VICS fuse (early production) or the RDO/S-Band/VICS (late production) on the BCM.
If both fuses are OK, diagnoise the audio amp. The amp, itself, contains no serviceable fuses.
Old Nov 15, 2007 | 09:38 PM
Bludog's Avatar
Bludog
Default blown amp
I bought my car used with a blown amp. The amp is in the door. If the head unit is working, you blew the amp. I remember seeing the dealer hook up a scan tool to check it.
Old Nov 15, 2007 | 09:55 PM
Miaugi's Avatar
Miaugi
The main amp is actually behind the firewall floor board on the passenger side of the car.
Old Nov 16, 2007 | 10:14 AM
Isaiah48's Avatar
Isaiah48
Thanks, I'll do that... I didn't even realize there was an Audio section...:o
Old Nov 16, 2007 | 10:18 AM
Isaiah48's Avatar
Isaiah48
I believe I checked all the one's under the hood and under the Passenger floor panel, but where is the BCM at?
Old Nov 16, 2007 | 11:02 AM
calemasters
Forward of the panel for the passenger's feet.
Old Nov 16, 2007 | 11:06 AM
Isaiah48's Avatar
Isaiah48
Behind the front right wheel housing.
Is there an actual fuse in the wheelhouse area attached to the BCM or is the fuse under the passenger floor panel that is for the BCM?
To Blown Bose Amp...
