Bcm,ecm,pcm??????
FWIW, I recall the number was something like 17 computers -- but that's a fuzzy memory. During my Museum Delivery tour at the factory, several folks referred to the C6 as a computer on wheels. It's really more of a portable local area network!
Most of the controls are really connected to the effectors (motors, etc) indirectly through the BCM. That sounds like a bass-akwards way of doing things, but there are some real advantages. By using small wire to carry signals (bigger, heavier wire is required to carry power) they save weight - probably around 100 lbs on the C6. Because the computer can check the inputs against the outputs, it spots problems early. And because it can report on problems there's a self-diagnostic capability, making it quicker (and cheaper) to fix a problem (most of the time).
But a network on wheels is a pretty good description. The ECM, TCM, BCM, CCM, and various terminals all communicate through the on-board networks.
The part that annoys me is that they do so little with it. There are almost unlimited possibilities available at almost no cost, because everything is under software control. Adding a few lines of code and some options is cheap, reliable and easy. What's lacking is the documentation to support this sort of stuff.
"check gas filler cap"
"check windshield washer fluid"
then later that day, the lites in the mirror-map/footwell came on by themselves; then later the dashboard instrument lites came on at full brightness.
the only thing like that before was a couple mos. ago, when the dash suddenly went dark. i am just logging everything for now, i called detroit/chevy and asked them to open a trouble ticket, which they did. i told them i intend to keep a running log of these electrical/'puter problems and will get back to them soon [i got their direct phone number and the open trouble ticket number].
one of my club's gearheads said it might be a dirty electrical junction part, or an EEPROM. apparently the wire control junction parts are cheap and can get dirty electrical connections, even at the factory.
stay tuned.
Thanks.
