Annoying!!!!
Old Nov 17, 2007 | 09:33 PM
lyonsac4242's Avatar
lyonsac4242
Default Annoying!!!!
Hey guys, I picked up my 05 Z51 6spd coupe 3 months ago and I am getting very annoyed by the rattles coming from the clamps on the removable top. Been lazy and it was cold today so i haven't checked to see if there is an easy way to adjust the tension in the clamps before they shut. It seems that if they were tougher to close, it would rattle less. Is this just a problem that I will have to live with , or is it an easy fix ? Thanks
Scott
Old Nov 17, 2007 | 09:43 PM
BAADC6's Avatar
BAADC6
Try wiping all the rubber surfaces with silicone grease...it is clear. I think it is also mentioned in the owners manual. It helped on my car.
Old Nov 17, 2007 | 10:02 PM
not08crmanymore's Avatar
not08crmanymore
Turn up the radio!
Old Nov 17, 2007 | 10:04 PM
Maui's Avatar
Maui
St. Jude Donor '08
I've found that how you install it and temperatures can affect it. Mine is pretty quiet.
Old Nov 17, 2007 | 10:11 PM
VET4LES's Avatar
VET4LES
Check out the adjusting new roof post at the top of this (tech) section. I put heat shrink on the post and it stopped the noise.
Old Nov 17, 2007 | 11:25 PM
jcosta79's Avatar
jcosta79
Scott
Install a cam and headers! You won't hear anything!
Old Nov 18, 2007 | 12:08 AM
Bludog's Avatar
Bludog
Default Roof rattle
Scott
There is a technical bulletin out at the Chevy dealer to lube and adjust them. Had mine done about a month ago and it took care of the problem.
Old Nov 18, 2007 | 09:14 PM
lyonsac4242
Thanks for the input will try some of those ideas, but my favorite is to get headers and a cam. That will happen all in good time.
Old Nov 20, 2007 | 01:07 PM
yellowc6ohio's Avatar
yellowc6ohio
yea take it to the dealer they will take care of it under warranty
To Annoying!!!!
