Need Help Lowering Wcc Bolts
Old Nov 23, 2007 | 12:28 AM
ground zero's Avatar
ground zero
Default Need Help Lowering Wcc Bolts
Guys I need some help, over the holiday I tried to install my WCC lowering bolts. The fronts went in with no problem, the rear a different story. What all do I have to take off and loose to get the old bolts out? From what I understood is you loosen the lower A arm and you can get to them ??????? I cant seem to get the a arm loose! The nut is loose but I cant get the a arm to drop at all. Please help me as my car is on jackstands I am about to go crazy
Old Nov 23, 2007 | 10:24 AM
ground zero
anybody???
Old Nov 23, 2007 | 11:15 AM
loco engineer's Avatar
loco engineer
Travis, If you are replacing the bolts, support the carwith jack stands under the frame. Then use a bottle jack under one side of the leaf spring at the end. Apply pressure at that point until the car starts to rise. This will leave the a arm down but preload the spring, creating a gap to unscrew the bolt and remove it. Hope this helps. Bill
Old Nov 23, 2007 | 11:37 AM
ground zero
I tried that and it doesnt drop the a arm enough. The bolt is like 1/2 inch away from coming out.
Old Nov 23, 2007 | 12:19 PM
Danny318's Avatar
Danny318
try making it 1/4 inch
Old Nov 23, 2007 | 02:44 PM
ground zero
DANNY, what??? I dont understand what you are trying to say?
Old Nov 23, 2007 | 06:38 PM
journeyc6's Avatar
journeyc6
-loose upper A arm
-remove sway bar
-pressure on the leaf spring
Old Nov 23, 2007 | 07:20 PM
ground zero
Default A HUGE THANKS TO vettealot
I want to take a second and say thankyou to vettealot, I appreciate you taking the time to call me and throughly explain how to do this. If you ever get to South Dakota let me know
Old Nov 23, 2007 | 10:06 PM
Danny318's Avatar
Danny318
nevermind I didnt read your post properly...
To Need Help Lowering Wcc Bolts
