Halltech Venom
Old Nov 23, 2007 | 09:26 AM
pc07vette's Avatar
pc07vette
Default Halltech Venom
I have been researching air induction systems and the Halltech Venom intake system seems to produce some additional hp and torque
with easy installation and no cutting. I guess this system is not really a cold air induction system since the air is taken from under the hood.
I think the Vortec Intake by Breathless Performance would be considered a true cold air intake since cutting of the shroud is required.
Is the performance that much better between an intake such as the Halltech and a true cold air intake such a the Vortec, Varrram, or Callaway.
Old Nov 23, 2007 | 01:43 PM
goatts's Avatar
goatts
15HP by cutting shroud. Zero otherwise.
Old Nov 24, 2007 | 12:59 AM
Myhardtop's Avatar
0Myhardtop
Former Vendor
Hello Mr. pc07vette,
Please consider this option...it works!
Thanks,
Carlos
Old Nov 25, 2007 | 07:56 PM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
Check this out.
Old Nov 25, 2007 | 08:44 PM
bunk22's Avatar
bunk22
I would say try a search and see which cold-air consistently showed gains at the track. Look at both the C6 and C5 section. You'll probably see one name pop up over and over.
To Halltech Venom
