I had my track wheels on this weekend. Just put the stock ones back on. Only getting reading from the front. No readings from the back... Any suggestions?
Also had the abs and active handling lights go on and off a few times at the track when the car got hot. No problems after it cooled for 20 minutes.
Have you driven your C6 since replacing the wheels? The sensors go to sleep mode after not being used for a period of time. I think you need to hit 20 mph again to start normal transmissions.
Did you do a "relearn" procedure with a TPMS tool when you swapped to your track wheels? If so, did you do the procedure for your street wheels when you put them back on?
If you did a relearn procedure with a TPMS tool, I'd say that you didn't do it properly after putting your street wheels back on - just do it again!
