DeWitts Radiator Group Purchase
Old Nov 29, 2007 | 12:16 AM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Default DeWitts Radiator Group Purchase
I usually do this in January but some of you indicated you would like to give/get xmas gifts so here we go again:
Sale ends December 15th only! No exceptions
$50 discount on all Direct Fit Radiators.
$100 discount on all radiator & fan combinations.
FREE SHIPPING!
To qualify for the discount you must:
1.Be a CF member
2.Order through our website http://www.dewitts.com
3.Use CFGP as part of your name in the order form, so we can ID them.
Each order will be automatically acknowledged WITHOUT the discount. Do not call or write to complain or question the non-discounted price. The system cannot adjust this, I will do it on our end and you will receive a corrected invoice. No Credit cards will be charged until the item is shipped.
Old Dec 1, 2007 | 07:41 AM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
ttt, you mean nobody with a C6 cares to save money?
Old Dec 1, 2007 | 08:45 AM
TEXASRANGER's Avatar
TEXASRANGER
HOOK-EM HORNS
St. Jude Donor '08
I have Tom's rad. in my 69, 74 and 80 C3's, and going to order one for one of my C6's today. Great product.
Old Dec 1, 2007 | 08:48 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
I put one on with the oil cooler and all my temps are down.
Great quality and great customer service.
Old Dec 1, 2007 | 09:17 AM
johnodrake's Avatar
johnodrake
Moderator
When I need to replace my OEM radiator, I will get a DeWitt
Old Dec 1, 2007 | 12:15 PM
runutzzzzz's Avatar
runutzzzzz
So would that be in 15 years? OR in the Spring?
Old Dec 1, 2007 | 12:17 PM
timd38's Avatar
timd38
One of my neighbors has one and says it is the only radiator to buy.
Old Dec 1, 2007 | 01:55 PM
Silverton's Avatar
Silverton
Tom, I've been planning to install your radiator this winter, so this is a big opportunity for me. What is the correct part number for a '07 C6 Z51 (w/EOC)? It was expressed on this forum that perhaps you had the part numbers reversed on your website for the Z51 vs. non-Z51. Thanks!
Old Dec 1, 2007 | 04:34 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
It is my understanding that 05 & 06 Z51's have the (EOC) engine oil cooler inside the radiator (internal) but the 2007 didn't have the oil cooler at all. If any disagrees with that I'd like to know?
If that's true, then use A05A for the automatic or A05M with 6spd.
You could also upgrade the radiator with the eoc and add the hose package if you like.
Old Dec 1, 2007 | 05:49 PM
Silverton's Avatar
Silverton
Tom, if the '07 Z51 does not have the EOC or a TOC, what was GM thinking? I would think that having an EOC and TOC would be very important.
Is the "upgrade" you're referring to the A05E radiator? What hose kit is required for this upgrade.
I'm just curious here, is there any way to fit a TOC to a '07 Z51?
Does the Z06 use a separate EOC? Can a separate EOC be installed on the '07 Z51?
Thanks!
Old Dec 1, 2007 | 09:58 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
a. Is the "upgrade" you're referring to the A05E radiator?
b. What hose kit is required for this upgrade?
c. I'm just curious here, is there any way to fit a TOC to a '07 Z51?
d. Does the Z06 use a separate EOC?
e. Can a separate EOC be installed on the '07 Z51?
Thanks!
a. Yes, unless you have an automatic, then A05AE
b. See the link below
C. A toc is (Transmission oil Cooler) for an automatic
D. Yes
E. Yes, the z06 does that.
http://forums.corvetteforum.com/show...light=10338247
Old Dec 1, 2007 | 11:30 PM
Silverton's Avatar
Silverton
Two questions:
(1) Would it be easier (less costly) to install a (separate) C6 Z06 oil cooler than to install the '05-'06 Z51 EOC line?
(2) Your A5AE is the only radiator listed for the C6 Z51, and your description is
This is a true Direct Fit for 2005 & 2006 Z51 option cars.
Doesn't this imply that all '05-'06 Z51's have an EOC and a TOC?
Old Dec 2, 2007 | 09:05 AM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Two questions:
I have no idea what the cost of the external cooler and hose package would be. You need to tell me what transmission you have. 6spd or A6 auto?
Old Dec 2, 2007 | 01:32 PM
Silverton's Avatar
Silverton
Tom, 6-speed manual. Would this be a better option for the A05E radiator than the difficult to install GM hose package: "install the #10AN fittings (included) and use SS hose assemblies [from your website]?"
Old Dec 2, 2007 | 04:40 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
If it was me, I would do everything I could to use the stock GM asssembly because it has a built in bypass which is a very nice items to have. Some people have said the install was simple and others have complained.
Old Dec 2, 2007 | 04:49 PM
dbratten's Avatar
dbratten
Tom, does the GM oil line assembly require any additional parts to mate with your A05AE that I ordered yesterday? Are the A6 lines also compatible, as shipped?
Thanks for the CFGP and any information.
--Dan
Old Dec 2, 2007 | 04:58 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
--Dan
If you have a 05-06 Z51, you're all set. If you have anything else, you would need to purchase the two quick connect fittings for the eoc connection at the radiator. I don't know what the fitting part number is but if anyone wants one of the GM hose assemblies I still have a couple. The A6 lines are the same as the stock radiator.
To DeWitts Radiator Group Purchase
Old Dec 2, 2007 | 05:14 PM
Vettlldo's Avatar
Vettlldo
Are all radiator's built today aluminum and the copper models kicked to the curb?
Old Dec 2, 2007 | 07:13 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Yeah, pretty much. The controversy of Aluminum vs Copper will probably go on forever but the higher weigh, cost of copper, and higher design capabilities of aluminum are driving the copper rads to the graveyard. That reminds me of a graphic I made a long time ago and never got to use. This seem like a good time.
Old Dec 11, 2007 | 12:34 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Only A Couple Days Left!!!
