RevXtreme Hot Cam Special!!!!!
Old Dec 3, 2007 | 01:54 PM
TLewis4095's Avatar
TLewis4095
Default RevXtreme Hot Cam Special!!!!!
Compare ALL that is included here, and all work is done in-house at our shop, one of the largest, best equipped shops in the State....not done in a garage or carwash stall. No re-using gaskets, valve seals, timing chain, etc. Also, we evac your AC system professionally with a computerized AC machine before opening the system, and then evac any moisture/contamination before recharging the exact amount of R134a your car requires.
This is complete, turn-key out the door:
Comp/RevXtreme custom grind 232/236 cam or any grind to .600 lift
Comp 918 springs
New valve seals
Comp Titanium retainers
Seats
Manley PR-4130 5/16 push rods
New water pump gaskets
new frnt cover gasket
New heavy duty timing chain
New frnt main seal
New crank bolt
Hi vol oil pump
New AC Delco oil filter
7 qts Mobil 1 10w30 (or other weight of choice)
Complete Dyno tune with street driveability
A/C evac & recharge
All this for $1947 plus tax C5/C6, $1847 F-body & GTO.
Call JP to schedule: 813-628-0080
Old Dec 7, 2007 | 08:13 PM
TLewis4095's Avatar
TLewis4095
Still running! Any lift to .600 for this price....over .600 extra charge for stronger springs.
Old Dec 14, 2007 | 11:49 AM
TLewis4095's Avatar
TLewis4095
Bump for a great special!
Old Dec 17, 2007 | 05:33 PM
TLewis4095's Avatar
TLewis4095
Ttt
Old Dec 18, 2007 | 11:14 AM
TLewis4095's Avatar
TLewis4095
Compare what you get in this package!
Old Dec 19, 2007 | 09:35 AM
TLewis4095's Avatar
TLewis4095
Ttt
Old Dec 19, 2007 | 09:41 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
No doubt that is a great deal for a turnkey installation!
Old Dec 22, 2007 | 08:30 AM
TLewis4095's Avatar
TLewis4095
Bump!
Old Dec 26, 2007 | 03:05 PM
TLewis4095's Avatar
TLewis4095
Ttt!
Old Jan 6, 2008 | 12:49 PM
TLewis4095's Avatar
TLewis4095
Extended for Jan!!
To RevXtreme Hot Cam Special!!!!!
