160 stat
Old Dec 10, 2007 | 01:17 PM
ffbor750's Avatar
ffbor750
Default 160 stat
can i put in a 160 thermostat without having to program the car, would it hurt anythiing if i didn't program it
Old Dec 10, 2007 | 01:21 PM
SpinMonster's Avatar
SpinMonster
It will aloow the car to run as low as 176 at cruise speeds but will not have the benefit at idle if the fan is not programmed for faster speeds per coolant temperature. The C6 fan comes on at 192 and cannot be changed in the tune for a lower temp start. It can be increased in speed at all temps though. Some have installed a switch with a speed control for the hottest of climates.
Old Dec 10, 2007 | 01:30 PM
ffbor750's Avatar
ffbor750
so i put in a 160 and also a switch then? that be right up my alley
Old Dec 10, 2007 | 02:15 PM
not08crmanymore's Avatar
not08crmanymore
If you have a predator or a programmer of some kind,you can adjust the fans to come on at different %'s and keep the temps near 200 +-,all day long sitting in traffic in 90 degree heat.
Old Dec 10, 2007 | 06:51 PM
timd38's Avatar
timd38
That's what I did.
Old Dec 10, 2007 | 06:58 PM
dennis50nj's Avatar
dennis50nj
this is best fan comes on 100% 181
http://www.cartek.net/parts/electron...csc6main.html#
Old Dec 10, 2007 | 08:05 PM
timd38's Avatar
timd38
Originally Posted by dennis50nj
For $50 more you can get a Preditor and have an OBDII reader also.
Old Dec 10, 2007 | 08:23 PM
dennis50nj's Avatar
dennis50nj
but can you hot lap and stay under 181 at the starting line and run 11.21 with that
To 160 stat
