I'm installing a Vararam on my 08 C6 (all day). I finally got everything installed, but don't know which pins to use to secure the red frame to the body of the car. I got the SCR1 (Z06 kit) and it came with 2 different sets of pins and 1 pair of metal washers. Both look like they will fit. I noticed that there are 3 holes per side but in order for the lower air duct to line up properly, the frame looks like it has to use the single hole which is off line from the other two??
Any help is greatly appreciated. I left Steve @ Vararam a message but didn't hear back today.
[QUOTE=JTDominate;1563144536]I'm installing a Vararam on my 08 C6 (all day). I finally got everything installed, but don't know which pins to use to secure the red frame to the body of the car. I got the SCR1 (Z06 kit) and it came with 2 different sets of pins and 1 pair of metal washers. Both look like they will fit. I noticed that there are 3 holes per side but in order for the lower air duct to line up properly, the frame looks like it has to use the single hole which is off line from the other two??
Should have two holes in the frame that are even and also let the vararam to line up. I used the bigger push-pin and no washer.
works fine.
Probably didn't help much.
It's been real good staying inplace.Plus they work well
Thanks man that helps, my chances when odds are 50/50 are like 30/70 that I get it wrong (LOL). I had a tough time getting the bottom piece to sit properly and getting the ring onto the MAF. My back is killing me, gonna take her out in a few.
