C6 Z51 swaybars
Old Dec 17, 2007 | 11:29 PM
coanan's Avatar
coanan
Default C6 Z51 swaybars
Would like to know the Dia./thickness of the front and rear. Thanks
Old Dec 18, 2007 | 01:27 AM
CMY SIX's Avatar
CMY SIX
rear 1 1/4 rear 1 1/2 front I think???
Old Dec 18, 2007 | 06:04 AM
coanan's Avatar
coanan
Thanks, can someone convert to MM
Old Dec 18, 2007 | 08:11 AM
User 81424's Avatar
User 81424
Originally Posted by Aaron Pfadt
Here are some diameters. Keep in mind that wall thickness and lever length also play a role in sway bar rate. The graph shows our current Pfadt offerings versus the GM bars. The Hotchkis bars fall roughly where the diameters would lead you.
Wayne O is probably right about the C6 base diameters, the Base C6 ones listed in my chart are copied from the C5. I generally do not pay much attention to those bars. The chart is accurate.
-Aaron
Spring rates also:
* C6 Base: 420# Front, 657# Rear
* C6 Z51: 526# Front, 645# Rear
* C6 Z06: 531# Front, 782# Rear
Old Dec 18, 2007 | 08:37 AM
FloydSummerOf68's Avatar
FloydSummerOf68
With that chart you can also see how insane it is to put a Z06 rear bar on with the stock rear tires...you're jumping for a 19mm rear bar to a 28 mm rear bar!!!! Holy potential oversteer.
Old Dec 18, 2007 | 12:26 PM
Aaron Pfadt's Avatar
Aaron Pfadt
St. Jude Donor '08
Autocross & Roadrace Forum Sponsor
Absolutely! For an upgrade path using stock parts, I always recommend the Z51 sway package. It has way better balance not only on non-z06 cars, but I would argue even on a Z06. Especially because most people go up in front tire size.
-Aaron
Old Dec 18, 2007 | 03:55 PM
coanan's Avatar
coanan
Thanks for the info, very helpful.
Old Dec 29, 2007 | 03:03 AM
2006c6keller's Avatar
2006c6keller
Default In Thousands Of An Inch - Z51 SWAYS
Get the micrometer out:
Z51 Sways:
Front: 1.222"
Rear: 1.008"
I got my micrometer out and doubled checked the measurements and they were "RIGHT ON" to the tables.
Old Dec 29, 2007 | 06:13 AM
timd38's Avatar
timd38
If you want to upgrade your bars, just get the Pfadt bars. They are the finest bars I have ever scene.
To C6 Z51 swaybars
