Exhaust Install Help
Old Dec 19, 2007 | 02:15 AM
Zteve's Avatar
Zteve
Default Exhaust Install Help
I'm going to install a set of Flowmasters on my 08 M6 this weekend. Didn't find too many threads on install tips. Is it necessary to remove the H pipe to get the exhaust in? Any other tips? Thanks in advance.
Old Dec 19, 2007 | 04:56 AM
Jim_H's Avatar
Jim_H
Yes you have to drop the H-pipe.
Instructions should have come with the exhaust.
Maybe this install video will help you
http://www.ecklers.com/product.asp?p...1329&video=yes
Old Dec 19, 2007 | 07:26 AM
rws.1's Avatar
rws.1
loosen and pull down on the sway bars.
You many need to remove the gas tank shield on the passenger side.
Old Dec 19, 2007 | 01:14 PM
LLWS's Avatar
LLWS
Properly block and lift the car.
Drop the rear sway bar.
Drop the H-pipe
Note that you need to loosen the little springy wires
Then carefully feed the exhaust cans over the rear axel and you're good to go.
It's very easy, as far as the installation, you'll want to have a second pair of hands when you go to connect the exhaust, because it's hard to hold and torque wrench without shouting and blue language.
In any event it's a two to three beer job, and dozens of smiles.
Old Dec 19, 2007 | 01:35 PM
MSC6's Avatar
MSC6
That video helped me a lot. It was however a real PIA to get the over axle pipes fitted into the stock H-pipe and everything tightened back up. Of course I only had the car up on ramps and was laying on my back.
To Exhaust Install Help
