This question is for people with A6 and 17" Drag radials.
I am just wondering if replacing my 19" with 17" drag radials for the the track, would the shift point change? I am worried that when driving in S mode and letting the car shift itself at the track, would the shift change so it would go over the limit since the rear tires are now 17"? Any feedback from drag racers would be appreciated.
Looking at BFG Drag 2s at The Tire Rack -- they show the 275/40/17 to have the same revs/mile as the OEM 285/35/19 with both at 805 even though there is over a inch difference in diameter. Most likely the DRs grow at speed. With the same rev/mile your shift points should remain the same.
I just put on some 275/40-17 Nitto drag radials and I haven't noticed a difference. Your shift points are based on both engine rpm and vehicle speed. But since the vehicle speed is picked up off the ring gear of the diff, it shouldn't make any difference as far as the size of the tires.
However, Dan points out that the drag radials must grow since both have the same revs per mile. Either way, you should be fine and my recent experience says it works.
Wide open throttle shift points are determined by engine redline ONLY. THey don't care what speed you are going. Furthermore, a 17" vs a 19" wheel makes absolutely NO difference. That's the diameter of the WHEEL, NOT the TIRE! You can buy tires in all kinds of diameters to fit any size wheel you want. It's the OUTSIDE diameter of the TIRE itself that makes the difference NOT the WHEEL diameter. That's why you have 25, 30, 35, 40 and 45 series tires to choose from. For your everyday driving you want the OUTSIDE diameter of the tire to be the same as the original OEM tires for the sake of traction control, active handling, abs and speedometer. So the TIRE size is what you want to compare. NOT the WHEEL size.
That seems odd to move up two sizes in wheel (17" - 19") but down only one size in aspect ratio (40 - 35). I went from 275/40/17s on my SS to 285/35/18 with no trouble. That's still a 25.5" tire. I've seen others here use 26.5 or 26.75" for the rear vette tire when doing gear change calculations.
I know that drag radials can grow, but my experience with nittos is that they grew much less than a slick, and a 35 sidewall doesn't have much give either.
I run the MT 17" drag radials. They absolutely cause your speedometer to read about 3 mph fast, verified by my buddies pacing me in the way to the track.
They dont affect my shift points, dunno if they will affect an automatics.
They do give you a nice gearing advantage that was worth about .10 in the 60 ft.
Why P275/40-17 (25.63 OD, 10.91 OW, 1433 LR, 811 Revs Per Mile) instead of say 315/35R-17 (25.79 OD 12.13 OW, 1874 LR, 806 Revs Per Mile)? Is it the higher load rating or too wide? Would you put Nitto's on the fronts or just stick with oem fronts? What 17" wheel would you use? I figure one would not use tire sensors on them, but how does that effect the DIC or computer?
That makes total sense to me. the 17" tire should be about 1" - 1.25" less in diameter than the factory 19" tire. That equates to roughly 5% or 3 mph at 60 mph. It's good to see some emperical evidence
The taller sidewall of the 17" is better, it absorbs more of the shock of launching as opposed to breaking traction or rear ends. A taller sidewall gives more "wrinkle". Kind of a marginal benefit with drag radials though. The real benefit is the Mickey Thompson compound, it is very sticky tried and true. My buddy was cutting 1.4's on his all night last night and he's got a C5 Z06 with a 6 speed.
I run stock tires up front and no sensors in my drag radials. I use C5 front wheels I had from my old C5. They fit fine, been using them for years. Most use C5 Z06 front wheels which are an inch wider. My track is 80 miles away, sometimes I get a DIC message on the rear sensors missing about 60 miles in and sometimes I don't. If I get the message I can't select Comp Mode, just traction control on or off. But it doesn't seem to affect anything else (that said I have Torque Management and traction control tuned out anyway).
Thanks much for the info! So no problemo's fitting and drag racing 275/40's on 17 x 8.5 wheels as opposed to 17 x 9.5 wheels? Those wagon wheels seem easier to find than the Z06 wheels.
