C6 1/4 Mile Performance Challenge
Old 11-03-2010, 06:19 PM
  #4581
Tommy D
Tommy D's Avatar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
Hey Kevin, Jeff & Josh Weicome to the list
Kevin is our first Grand Sport entry
Jeff nice run
Josh great run right up there on the internal mod LS2 list
Old 11-05-2010, 11:28 PM
  #4582
8850
8850's Avatar
Improved a little from my last. Burnout in first gear paddle about 10 seconds to get good smoke coming off the tires. At launch no noted spinning. HP Tuner log showed timing at 100% throttle was +6.5 degrees of advance increasing to 10.5 at 2 mph, 18.5 at 5 mph, 22 at 10 mph. At 100% throttle my rpm was 1543 climbing to only 2110 at 10 mph. Rated peak torque of 4600 occured at 30 mph. This automatic is sure in need of a loose converter. No KR recorded so could probably add more launch timing but with this tight converter it's just not going to make power at 1600 rpm regardless of advance. Launch IAT was 117* dropping to 97* on the 1-2 shift, 86* on my 2-3 and 77* at the lights.
This was my third pass. First two had mega spinning at launch due to not quite enough burnout. 11.7s on my first but with 121.10 mph.
Thanks for keeping this list for us Tommy!
1. Your entire profile completed
2. A copy of your entire time slip posted to the thread as in post # 4587
3. The complete the details of your pass using this template in your post:
4. Year Corvette - 2008
5. Type of Trans - automatic
6. Type of Suspension - stock
7. Stock Performance options - Z51, 2.73 gear, NPP exhaust
8. Tires utilized - 285/35/19 Invos
9. Modifications if any -Headers, CAI, UDP, tune
10. Dyno numbers if you have them
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc - Nitto 285/35/19, 25 psi in rear and 35 in front.
12. Typed in the post (as some time slips get deleted & etc after being posted)
___ Name of the Track - Houston Raceway Park
___ Date of the pass & weather conditions - November 5, 2010, about 60 degrees
___ 60'............. - 1.843
___ 330'........... - 4.981
___ 660'........... - 7.517
___ 660’ mph....- 98.03
___ 1000'......... - 9.679
___ 1320'......... - 11..514
___ 1320’ mph…- 120.32
Old 11-06-2010, 10:58 AM
  #4583
FloydSummerOf68
FloydSummerOf68's Avatar
I won't bother putting the actual timeslip in this post, becauase I plan on bettering my time on Sunday when I go back to HRP. I went racing last night and it was a BEAR for me to try and get traction. The new Yank I got installed was destroying my Nitto DRs unless I was leaving the line easy. I didn't see 8850 there...he possibly left before I got there. My dad and I didn't see any other C6s running any decent times. Most were in the high 12s or low 13s with one C6 Z06 running low 12s. It was unfortunate.
The car made three passes at over 119 mph with the best being 119.81mph, so I'm somewhat feeling that the 367 dynopull I got was a bit on the stingy side (it was done in 3rd gear also).
Overall it was an OK night. It's just unfortunate that my best pass was leaving a lot on the table on the launch. Anytime I tried to stall it up it would obliterate the tires through the 60. Time for longer burnouts and lower pressure.
4. Year Corvette - 2007
5. Type of Trans - A6
6. Type of Suspension - Z06 Swaybars and Z51 Brakes
7. Stock Performance options- None
8. Tires utilized - 275 Nitto 555r DRs at 22psi
9. Modifications if any - Ebay Longtubes w/ Offroad X, K&N Intake, Borla Stingers, Tuned, 3200 Yank
10. 367/368
11. 8 Second Burnout, Left from Idle
___ Name of the Track - Houston raceway Park
___ Date of the pass & weather conditions - Nov 5, 2010, -500 DA
___ 60'.............1.732
___ 330'...........4.928
___ 660'...........7558
___ 660’ mph....93.99
___ 1000'.........9.824
___ 1320'.........11.723
___ 1320’ mph…118.85
Old 11-06-2010, 12:44 PM
  #4584
8850
8850's Avatar
Sorry I didn't see you last night. I saw one black but no silver. I left right after my last pass at 7:45. I do need to change my tune and go back again. I found some KR in 3rd gear. I think I'm pretty much peaked out on et as even eliminating that KR in 3rd gear would result in much more et. And too they remined me on that 11.51 pass that I'm almost peaked on what I can run without a roll bar.
Get some ET Streets and your traction problem will be solved. Still running the same headers you showed me at Sear Hardware parking lot?
Old 11-06-2010, 02:02 PM
  #4585
da vette guy
da vette guy's Avatar
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc - 25 psi in rear and 35 in front. 62* according to the thermometer in my car.
nice pass, Larry...
Old 11-06-2010, 06:19 PM
  #4586
FloydSummerOf68
Yeah, I got there right at 8, so we missed each other.
Yep...same headers. I guess I'm proving that they make power trapping ~119 consistantly in a basically intake/exhaust LS2
ET Street Radials will be coming, but I know I can work these down into consistant 1.6s. It's just a matter of seeing how much pressure and how much burnout it takes. 5-6 more passes and I should start getting a lot more consistant with it and I feel I'll be making high 1.6 60's regularly and working on low 1.6s.
Congrats on your 11.5 run....that's getting pretty quick If you start running sub 11.5s just take it out to Lonestar Motorsports Park...you can run the times without a rollbar there. I raced there exclusively for the last year while HRP didn't have Sunday Test N Tunes.
Old 11-06-2010, 07:09 PM
  #4587
8850
8850's Avatar
yep, we missed each other.
I found that Nitto DRs don't hold very good at all back when I had my Camaro. Not sure about ET Street Radials but I know ET Streets hold much better than Nitto DRs.
I would give a buck or two for your 1.73 60' time. You have your LS2 moving very good now with more to come!
Old 11-06-2010, 07:15 PM
  #4588
FloydSummerOf68
I have run 255 ET Street Radials to high 1.5 60's back when I was racing my firebird. I prefer them over ET Streets because they're a lot more friendly to drive to and from the track on them. If I were running a manual I'd run ET Streets though for the softer sidewall...helps to not shock the drivetrain as much on launch.
I know Nittos aren't the best...they were working great before the converter though. I'll go out a few more nights with them and see if I can get them to work. If not i'll be swapping out.
Old 11-07-2010, 08:39 AM
  #4589
theofel
theofel's Avatar
St. Jude Donor '10-'13
Cooler weather over the weekend in South Florida. Took a ride to Palm Beach International Raceway saturday evening to take advantage of this low humidity and cooler weather(55 degrees). My bolt-on LS3 ran it's personal best eighth mile and quarter mile.
60'...1.54
1/8...7.15@95.98
1/4...11.21@121.18
I will try to get a friend to send the time slip in. Not really computer savy, I'll try to get in on Monday!
PS...Don't get all excited if your an LS3 fan...I got beat by a bolt-on LS2 (dicky). He ran a 11.16@122.36 mph...
Old 11-07-2010, 09:42 AM
  #4590
8850
8850's Avatar
60'...1.54
1/8...7.15@95.98
1/4...11.21@121.18
Great times for bolt ons! How in the world do you get a 1.54 60'. My best is a 1.843 and with no spinning.
Old 11-07-2010, 10:57 AM
  #4591
theofel
theofel's Avatar
MY LS3 A6 has 335/18 Hoosier drag radials mounted on C5, ZO6 12" Rims ,3600 stall and 3.15 gears. Track hooked well last night. My previous best 60's were 1.56 and 1.57's. Changing the converter yeilded about .3...Big difference in 60'.
Old 11-07-2010, 11:13 AM
  #4592
FloydSummerOf68
Congrats on the run!
Very nice times.
Old 11-07-2010, 11:25 AM
  #4593
8850
8850's Avatar
Converter! Now I understand. Is a converter considered a bolt on? I know it has been discussed. I need one!
.3 change in 60' would be about .5 in the 1/4 mile. And too with a converter you keep the rpm up at shift. Mine feels like it kinda falls on it's face a little on that 2-3 and 3-4.
Old 11-07-2010, 11:35 AM
  #4594
FloydSummerOf68
Yes, a converter is a bolton.
Old 11-07-2010, 12:16 PM
  #4595
LS1LT1
LS1LT1's Avatar
1.54 is very strong, congrats theofel and all of the other new bests above.
My best ET also came from a 1.54 as well, my best ever sixty foot so far is a 1.52.
Absolutely.
Old 11-07-2010, 01:42 PM
  #4596
dicky
dicky's Avatar
60'...1.54
1/8...7.15@95.98
1/4...11.21@121.18
congrats mike
Old 11-07-2010, 07:50 PM
  #4597
pettvette
pettvette's Avatar
CI 5-6-7-8-9-10-11 Vet
Hey Tommy, if you could find a place on a list for my new best times for my bone stock (with a twist, see below) 08 A6 2.56 geared car.
4. Year Corvette ...2008
5. Type of Trans ...A6, 2.56 gears
6. Type of Suspension...Base
7. Stock Performance options (as in optional gears with the automatic, & etc.) STOCK, no tune, stock thermostat
8. Tires utilized ... Original GoodYears... rears set to 28 lbs.
9. Modifications if any... Propped Shroud.. Air Filter Removed...
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc..... Trans in Sport Mode... No Paddles...Power Braking to 1,000 rpm... 3/8 tank of gas... All nannies off...
___ Name of the Track... Beech Bend
___ Date of the pass & weather conditions.. 11/6/2010 44 degrees.. DA Negative 909
___ 60'.............1.88
___ 330'...........5.15
___ 660'...........7.81
___ 660’ mph....92.89
___ 1000'.........10.09
___ 1320'.........12.01
___ 1320’ mph…116.26
2 more runs
To C6 1/4 Mile Performance Challenge
Old 11-07-2010, 08:38 PM
  #4598
dicky
dicky's Avatar
60'...1.54
1/8...7.15@95.98
1/4...11.21@121.18
hey mike i dont know why i didnt think about this last night but i have a copy of that run so ill post it for you.
  #4599
FloydSummerOf68
Please add me to the LS2 External Mod listing...thanks
7. Stock Performance options - none
8. Tires utilized - 275/40/17 Nitto 555R 19psi
9. Modifications if any:
Ebay Longtubes and Offroad X
K&N Intake and Vette-Air scoop
Yank 3200 Converter
10. Dyno numbers if you have them: 365rwhp in 3rd gear
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc - 19psi in rear, 45psi in front. 2000rpm launch with 15-20 feet of wheel spin
___ Date of the pass & weather conditions - 11/7/10 and -197 DA
___ 60'............. - 1.715
___ 330'........... - 4.873
___ 660'........... - 7.473
___ 660’ mph....- 95.24
___ 1000'......... - 9.708
___ 1320'......... - 11.583
___ 1320’ mph…- 119.12
Old 11-07-2010, 08:45 PM
  #4600
dicky
dicky's Avatar
time slip for theofel
Quick Reply: C6 1/4 Mile Performance Challenge
