C6 1/4 Mile Performance Challenge
Old Nov 19, 2013 | 12:54 PM
  #6721
Vade46's Avatar
Vade46
I really don't even want to post this since I am disapointed with my results, but it is slightly faster than my previous best. I put in a ZR1 clutch which I couldn't get off the line good at all. I have a Mantic 9000 on the way and then I will have the results I was looking for.
Category : LS2 External Modification
1. Your entire profile completed & read Instructions: Yes
2. A copy of your entire time slip posted to the thread as in post # _6723_
3. The complete details of your pass using this template in your post:
4. Year Corvette : 2007
5. Type of Trans : M6
6. Type of Suspension : Z51
7. Stock Performance options (as in optional gears with the automatic, & etc.) : Z51
8. Tires utilized : 275/40/17 Hoosier DR's on chrome C5 ZO6 replica's/ GTO spares with M&H Racemaster Bias-Ply
9. Modifications if any : AR Headers w/Cats, Corsa Sport CB, Callaway CAI, MGW shifter, Ported FAST 102, Ported stock TB, RPM stage 4 rear w/4.10 gears, ATI 10% UDP, ZR1 Clutch, 160 t-stat, Deka Battery, Vette Doctors Tune
10. Dyno numbers if you have them : 412hp/419tq
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc : 18psi rear tires/ 35psi fronts, launched at around 4000-4200rpm, passenger seat and front sway bar removed, 1/8th tank of gas, 240lb driver
___ Name of the Track - Atco
___ Date of the pass & weather conditions -11/4/13 40-45 degrees (time slip date is wrong)
___ 60'.............1.739
___ 330'...........4.980
___ 660'...........7.589
___ 660’ mph....94.40
___ 1000'.........9.80
___ 1320'.........11.650
___ 1320’ mph….122.57
Copy of Time Slip Below:
Old Nov 19, 2013 | 06:18 PM
  #6722
tucn26's Avatar
tucn26
Category :Power Adders LS2
1. Your entire profile completed & read Instructions:Yes
2. A copy of your entire time slip posted to the thread as in post # _____
3. The complete the details of your pass using this template in your post:
4. Year Corvette 2005
5. Type of Trans A4
6. Type of Suspension Stock
7. Stock Performance options (as in optional gears with the automatic, & etc.) 3:15 gears
8. Tires utilized 275-40-17 MT
9. Modifications if any LG headers, fast 102, cam/springs, alky meth, 3600 converter, rpm trans, a&a t trim
10. Dyno numbers if you have them 660 hp
12. Typed in the post (as some time slips get deleted & etc after being posted)
___ Name of the Track Evadale Raceway
___ Date of the pass & weather conditions 11/9/19 overcast 60 degrees
___ 60'............. 1.52
___ 330'........... 4.09
___ 660'........... 6.23
___ 660’ mph.... 114
___ 1000'......... 8.09
___ 1320'......... 9.66
___ 1320’ mph… 141
Old Nov 20, 2013 | 08:35 PM
  #6723
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
New or Improved times:
10.982 @ 124.91 Amwells1
12.305 @ 116.51 JBrunoJSBC6
11.650 @ 122.57 Vade46
09.668 @ 141.15 Tucn26
If your time has not been posted it is because you have not followed the requirements for posting your time. I need the entire time slip as well as the template included in your request as required on page one.
Historical Record:
Showroom Stock LS2 (2005 -2007)
12.215 @ 115.45 - LS1LT1 - 06 A6 - (1278)
12.235 @ 115.58 - 06C6FVR - 06 M6 Z51 - (333)
12.290 @ 114.29 - Proney - 07 M6 - (4500)
12.314 @ 114.82 - CYA Vett - 05 M6 F55 - (675)
12.422 @ 113.90 - DrRichie - 05 M6 Z51
12.499 @ 114.90 - Jschindler - 05 M6 Z51
12.53x @ 113.00 - Wicked07C6 - 07 M6 Z51 - (914)
12.540 @ 113.59 - Tony 63 Vette - 06 A6 - (1510)
12.548 @ 113.74 - Tony96LT4 - 06 A6 Z51 - (1149)
12.56x @ 113.39 - Red Sleeper - 06 A6
12.56x @ 112.00 - Orange C6 - 05 A4 Z51 - (56)
12.650 @ 111.65 - Zippin Zee - 05 M6 Z51 - (48)
12.665 @ 113.03 - Mdrrandall - 07 M6 Z51 - (1675)
12.693 @ 114.88 - Prankster - 06 M6 - (1621)
12.69x @ 112.32 - Silverlx - 06 A6 - (872)
12.703 @ 112.43 - Jelsis - 06 A6 Z51 - (452)
12.70x @ 113.00 - Blackmajik - 07 A6 - (1627)
12.71x @ 111.30 - Flyin05 - 05 M6 Z51
12.71x @ 111.00 - Demented - 05 A4 Z51
12.74x @ 108.67 - Shooter 49 - 05 A4 3.15 - (39)
12.756 @ 112.57 - C5Pilot - 07 A6 Z51 - (903)
12.757 @ 109.25 - Ponchorello - 05 A4 3.15 - (990)
12.795 @ 112.17 - Jchazr - 05 M6 Z51 - (447)
12.80x @ 111.00 - SheDevilC6 - 07 A6 Z51 - (1668)
12.81x @ 112.83 - Vette-oholic - 05 M6 Z51 - (494)
12.817 @ 110.95 - SkyKing - 07 A6 F55 - (2480)
12.85x @ 114.53 - Mr Z51 - 06 M6 Z51
12.917 @ 111.67 - Brewcitygymratt - 06 A6 - (4578)
12.936 @ 111.40 - DiggyMoe - 07 M6 - (965)
12.97x @ 108.00 - Ginny C6 - 05 A4 F55 - (56)
12.98x @ 108.00 - Tampa Vet - 05 A4 3.15 - (119)
12.99x @ 111.70 - C64ME - 05 M6 Z51 - (329)
13.04x @ 109.15 - TMyers - 06 A6 - (528)
13.054 @ 113.31 - RDunn - 06 M6 - (982)
13.10x @ 108.70 - Rothchilds - 05 A4 F55 3.15
13.12x @ 110.40 - JDWK - 05 M6 Z51
13.25x @ 110.60 - C6 Matt - 05 M6 Z51 - (118)
13.267 @ 108.59 - Sfadchi - 06 A6 Z51 - (884)
13.26x @ 105.30 - Joeking - 05 A4 Z51 - (657)
13.30x @ 107.00 - Shurite44 - 06 A6 Z51 - (764)
13.35x @ 108.10 - Phatpharmd - 06 A6 - (591)
13.62x @ 106.18 - Rich28 - 05 A4 Z51
Showroom Stock LS3 (2008 - 2013)
11.718 @ 119.94 - AndrewZPSU - 08 M6 - (2586)
11.806 @ 118.82 - Gmrulz - 08 A6 Z51, NPP - (3478)
11.974 @ 116.98 - Proney - 08 M6 Z51, NPP - (4652)
12.058 @ 122.05 - AndrewZPSU - 10 A6 NPP - (5051)
12.100 @ 115.19 - Odin - 09 A6 2.73 npp - (4325)
12.102 @ 117.60 - Dingrao - 08 A6 - (3561)
12.127 @ 116.59 - Pettvette - 08 A6 - (4278)
12.159 @ 115.59 - Old Goat - 09 A6 2.73 - (3708)
12.167 @ 117.15 - DarkOctane - 08 A6 NPP - (6310)
12.167 @ 116.54 - Vinsane112 - 08 A6 2.73 - (2740)
12.186 @ 117.72 - Hardhattg - 08 M6 Z51 - (2686)
12.237 @ 112.86 - 940CACC - 08 A6 - (2871)
12.244 @ 117.83 - 74Vette - 08 M6 - (4617)
12.305 @ 116.51 - JBrunoJC6 - 08 A6 NPP - (6722)
12.400 @ 116.36 - RandyDank23 - 08 A6 - (6059)
12.262 @ 115.22 - Oklahoma - 08 A6 - (3765)
12.276 @ 118.66 - EZ28 - 08 M6 Z51 NPP - (3247)
12.355 @ 117.47 - Bain - 08 A6 NPP 2.73 - (2755)
12.357 @ 116.94 - TNorman - 08 A6 NPP - (4227)
12.408 @ 116.11 - XtremeChubbles - 08 A6 Z51 - (6589)
12.409 @ 114.70 - Jschindler - 08 M6 Z51 NPP - (2132)
12.419 @ 116.15 - JTorchz06 - 09 A6 Z51 NPP - (3185)
12.412 @ 115.38 - HOXXOH - 08 A6 F55 - (2478)
12.428 @ 116.67 - Pea-Jay - 08 A6 - (4448)
12.494 @ 115.54 - 1.8T - 08 M6 Z51 - (2310)
12.500 @ 115.53 - Shane Fap - 08 A6 - (6298)
12.514 @ 116.73 - SK360 - 08 A6 2.73 - (6283)
12.552 @ 114.70 - Larry R - 08 A6 2.73 - (4054)
12.600 @ 114.12 - Beefcake - 08 A6 - (2875)
12.658 @ 114.99 - PhillyLS1 - 09 M6 - (3151)
12.668 @ 113.61 - CFP40 - 08 A6 NPP 2.73 - (2828)
12.689 @ 112.07 - Bfppt1 - 10 A6 - (5300)
12.747 @ 114.31 - Detoxx03 - 08 M6 NPP- (4057)
13.354 @ 110.78 - M453W - 09 A6 NPP- (5708)
13.428 @ 109.32 - Dan Wendling - 09 A6 NPP - (4032)
Showroom Stock LS3 Grand Sport (2010 - 2013)
12.319 @ 115.75 - Grand SportMan - 10 A6 - (5128)
12.559 @ 115.41 - Fastenuf - 11 A6 - (5269)
12.805 @ 113.33 - PhillyLS1 - 11 M6 NPP - (5085)
________________________________
External Engine Modifications LS2 (Bolt-Ons)
10.626 @ 126.98 - Dennis50NJ - 05 A4 Z51 - CAI, cb, conv, ewp, pfast, 3.73, hdr, ptb, tune, & more, DR - (3944)
10.788 @ 127.29 - LS1LT1 - 06 A6 - CAI, conv, fast, hdr, ptb, skinnies, tune, & more, DR - (5611)
10.936 @ 123.01 - Dicky - 06 A6 - CAI, conv, cutouts, fast, 3.42, hdr, & more tune, DR - (5485)
11.121 @ 124.49 - Teetheriot - 07 A6 - CAI, conv, fast, hdr,nc , Z06 muff, & more, tune, DR - (5869)
11.293 @ 122.24 - JMT1669 - 06 A6 - CAI, conv, cb, fast, 3.42, hdr, tune, DR - (4427)
11.295 @ 122.29 - FloydSummer of 68 - 07 A6 - CAI, conv, Pfast, hdr, no cats, tune, udp, DR - (5105)
11.342 @ 125.78 - Silvervette05 - 05 M6 – pfast/tb, gto skinnys, Z06 exhaust, tune, DR - (4422)
11.412 @ 119.27 - Devilish34 - 07 M6 - CAI, hdr, pfast, Z06 rear, tune, DR - (5536)
11.495 @ 121.77 - NastyS1K M6 – Cai, cb 3.90,pfast/tb, gto skinnys, tune, DR - (6669)
11.667 @ 118.76 - Its Stock - 06 M6 - CAI, hdr, udp, tune, DR - (4565)
11.650 @ 122.57 - Vade 46 - 07 M6 Z51 - CAI, hdr, tune, DR - (6723)
11.747 @ 120.83 - Siffert - 07 A6 - CAI, cb, pfast, hdr, skinnies, tune, DR - (3982)
11.76x @ 119.00 - NastyC6 - 05 A4 Z51 - CAI, conv, 3.73, hdr, pi/tb, tune
11.775 @ 121.58 - Red06vette - 06 A6 Z51 - CAI, cb, hdr, pi/tb, tune - (2175)
11.792 @ 117.26 - 06C6FVR - 07 M6 - CAI, 3.90, Z06 exhaust, tune, DR - (3225)
11.811 @ 118.76 - Joe G - 05 M6 Z51 - CAI, 3.90, hdr, pi, tune, DR - (1870)
11.879 @ 120.02 - C5pilot - - 07 A6 Z51 - CAI, hdr, pi, tune, DR - (3554)
11.87x @ 112.99 - Cucchiara - 05 A4 - CAI, cb, conv, hdr, tune, DR - (835)
11.937 @ 115.77 - DMcRacer - 07 A6 Z51 - CAI, conv, Z06 exhaust, tune, DR - (5438)
11.94x @ 117.99 - JimSpeed - 06 M6 Z51 - CAI, cb, hdr - (525)
11.969 @ 118.98 - GMRULZ - 06 M6 Z51 - Bilstein shocks, cai, hdr, pi, tune, DR - (2159)
11.98x @ 116.44 - C6speedjon - 07 M6 Z51 - CAI, cb, hdr, pi/tb, tune, DR - (1966)
12.01x @ 116.00 - Mr Z51 - 06 M6 Z51 - CAI, cb, hdr, pintake, tune, DR
12.03x @ 118.50 - Serendipity - 06 M6 - CAI, cb, hdr
12.035 @ 118.43 - Glennhl - 06 A6 Z51 - CAI, hdr, pi, tune, DR - (2273)
12.05x @ 117.02 - CYA Vett - 05 M6 F55 M6 - Hdr
12.052 @ 113.71 - Justasheet - 05 A4 Z51 - CAI, cb, 3.73, hdr, tune, DR - (4467)
12.084 @ 117.00 - Forrest - 06 M6 Z51 - CAI, cb, hdr, tune, DR - (1445)
12.091 @ 114.63 - 68RSSS -05 A4 F55 - CAI, hdr, tune - (5066)
12.133 @ 116.10 - ParisTNdude - 06 A6 - CAI, cb, hdr, tune, DR - (6566)
12.136 @ 115.15 - Ben Diss - 07 M6 F55 - CAI, hdr, tune, Nitto Ivos - (1915)
12.154 @ 118.81 - Blf0005 - 06 M6 - CAI, cb, eco, hdr, pfast, tune, - (6582)
12.169 @ 116.82 - Gmkillr - 07 M6 Z51 - CAI, cb, fast, hdr, x pipe, tune, Dr - (6345)
12.174 @ 114.58 - C6dreamvette - 05 A4 - CAI, no muff, tune, kdw - (2185)
12.17x @ 119.00 - RHecox - 06 A6 Z51 - CAI, cb, hdr - (1224)
12.18x @ 115.85 - Mdrrandall - 07 M6 Z51 - CAI, cb - (1818)
12.18x @ 114.00 - Toptoneone - 06 M6 Z51 - CAI, cb, hdr, tune, DR - (1820)
12.216 @ 115.98 - Mike Campbell - 06 A6 - CAI, DR - (5093)
12.219 @ 115.14 - Shocker Racing - 05 M6 - Homemade Air filter, DR - (1319)
12.22x @ 116.70 - Ponchorello - 05 A4 3.15 - CAI, hdr, tune - (1702)
12.26x @ 119.40 - Dstage - 06 M6 - CAI, cb, fast, hdr, - (654)
12.26x @ 116.65 - Waveblaster785 - 06 A6 Z51 - CB, fast, hdr, - (1114)
12.275 @ 115.94 - TNTC4Vette - 06 M6 Z51 - Bilstein shocks, cai, hdr, no cats, ptb, tune, Ps2 (5018)
12.278 @ 114.19 - Stanger383 - 05 A4 3.15 - CAI, hdr, Z06 Muff, tune - (4223)
12.285 @ 114.46 - AngeloC6 - 05 A4 F55 3.15 - CAI, cb, hdr, hankook tires, tune - (6300)
12.293 @ 118.41 - Ganador01 - 06 A6 F55 - CAI, Fast, hdr, tune (6263)
12.319 @ 115.85 - Dave2007 - 07 A6 Z51 - CAI, cb, hdr, tune - (3625)
12.371 @ 112.29 - CTVette05 - 05 A4 3.15 - CB, hdr - (64)
12.378 @ 117.67 - Nicodemus - 05 M6 - CAI, cb, gears, hdr, tune - (364)
12.384 @ 116.78 - Goatdad - 06 A6 - CB - (6489)
12.391 @ 115.50 - Tony96 LT4 - 06 A6 Z51 - CAI, ptb, DR - (1469)
12.398 @ 115.47 - Berk4422 - 07 A6 - CAI, cb, hdr,ptb/I, tune - (6536)
12.42x @ 116.12 - YellowVette22 - 05 M6 F55 - CAI, cb, hdr, DR - (393)
12.483 @ 113.52 - EvlJake - 07 A6 - Cb, tune - (6051)
12.49x @ 114.43 - Colinsmom - 06 A6 Z51 - CAI, cb, hdr
12.49x @ 113.50 - 12 Oh- 06 A6 - CAI, cb, hdr, tune, DR - (1245)
12.50x @ 118.00 - Larry Chip - 05 M6 - CAI, cb, tune - (173)
12.50x @ 115.20 - Flooznie - 05 A4 - tune - (212)
12.515 @ 113.56 - Jelsis - 06 A6 Z51 - CAI - (488)
12.522 @ 115.26 - Tony B4 - 06 A6 - CAI, cb, hdr, tune - (1598)
12.525 @ 115.10 - USAF_C6 - 06 A6 - CAI, cb, hdr, tune - (4408)
12.525 @ 112.09 - H-Z/28 - 06 M6 - Cb, no cats, tune - (6362)
12.534 @ 114.99 - BMT03-mach1 - 05 M6 - CAI, no cats, tune (4572)
12.539 @ 113.78 - Ultimate CC - 07 M6 Z51 - CAI - (1641)
12.54x @ 113.63 - Anky1631 - 05 M6 - CAI, cb
12.55x @ 114.95 - Shurite44 - 06 A6 Z51 - CAI, cb, hdr (839)
12.55x @ 111.98 - 2003Anniversary - 05 A4 Z51 - CAI, cb, hdr - (236)
12.590 @ 111.46 - 07Cobaltss/sc - 07 A6 F55 - CAI, cb, 3.42, RE11, tune - (5239)
12.59x @ 114.89 - AZVette2005 - 05 M6 Z51 - CB hdr, tune - (198)
12.59x @ 113.46 - Badassbu - 07 A6 - CAI - (1765)
12.60x @ 114.00 - SScamaro - 05 M6 Z51 - CAI, cb, hdrs, tune - (56)
12.627 @ 111.69 - GTkiller97 - 05 M6 Z51 - Ivos - (4521)
12.636 @ 112.93 - 05Vettelag - 05 A4 F55 3.15 - CAI, cb, tune
12.63x @ 112.35 - Lusky - 06 A6 Z51 - CAI, 325 tires
12.65x @ 113.70 - Hitman99 - 06 A6 - CAI, hdr, tune
12.683 @ 111.39 - 30Milesoffshore - 05 M6 - CAI, cb, tune - (2598)
12.68x @ 113.92 - Sditch - 05 A4 Z51 - CAI - (184)
12.712 @ 113.70 - C6Brian - 07 M6 - Tune - (1614)
12.770 @ 110.18 - CMB13 - 05 M6 Z51 - CB, DR - (1265)
12.78x @ 112.50 - Dan-t - 06 A6 - Tune - (1175)
12.797 @ 115.58 - Sebaj - 05 M6 - CB, pi/tb, ud, Z06 exhaust, tune - (4435)
12.83x @ 111.00 - TMyers - 06 A6 - CAI, tune - (764)
12.88x @ 112.50 - MickyC6 - 05 M6 - CAI, cb, tune
12.891 @ 112.57 - Bunk22 - 05 M6 Z51 - CAI, cb, hdr, rockers, tune - (856)
12.89x @ 112.00 - Tom400CFI - 05 M6 Z51 - CB -(826)
12.900 @ 114.83 - Normlunt - 05 M6 Z51 - tstat - (537)
12.933 @ 110.64 - C6Vette - 06 M6 Z51 - CAI, cb, tune - (1202)
12.97x @ 111.22 - Zoli007 - 06 M6 Z51 - CB - (222)
12.97x @ 109.00 - Tsnipe11 - 05 A4 Z51 - CAI, hdr, tune - (693)
12.994 @ 111.25 - Parkev - 05 M6 Z51 - CB - (79)
13.30x @ 110.00 - Chempowr - 05 M6 F55 - CAI, cb - (1037) high alt
13.32x @ 108.87 - CorvettePilot - 05 M6 Z51 - CB
13.953 @ 104.94 - Fright88 - 06 A6 - CB, hdr - (1679) high alt
External Engine Modifications LS3 (Bolt-Ons)
10.820 @ 125.82 - HOXXOH - 08 A6 F55 - CAI, conv, ptb, Z06 Exhaust, tune, & more, DR - (4804)
10.888 @ 125.25 - 8850 - 08 A6 NPP 2.73 - CAI, conv, gto skinnies, hdr, udp, tune, DR - (6178)
10.987 @ 124.66 - Theofel - 08 A6 - CAI, cb, conv, 3.15, hdr, tune, & more DR - (4739)
11.252 @ 125.07 - Jbsblownc5 - 08 M6 Z51 - CAI, cb, 3.73, hdr, pi, torco & meth inj, tune, DR - (3739)
11.301 @ 123.54 - JohnDaMan - 08 A6 - CAI, cb, conv, hdr, ptb, udp, tune, DR - (6391)
11.468 @ 123.52 - Shane Fap - 08 A6 - CAI, hdr, tune, Z06 muff, Nittos - (6354)
11.468 @ 119.14 - HPAvette - 08 A6 Z51 NPP 2.73 – CAI, conv, hdr, tune, DR - (5241)
11.519 @ 122.72 - James1990 - 08 A6 Z51 NPP - CAI, cf/ hood, hdr, ptb, Z06rear, tune, Invos - (3565)
11.537 @ 121.20 - XStang - 08 A6 Z51 - CAI, Conv, hdr, ptb udp, tune, DR - (3735)
11.545 @ 123.09 - JerzeyLS3 - 08 A6 – CAI, CBx, hdr, tune, DR - (5146)
11.558 @ 120.71 - StageIt - 08 M6 Z51 - CB, hdr, fast, 3.90, Et St - (3085)
11.56x @ 120.02 - Quicktime - 08 M6 - CAI, cb, hdr, pi/tb, tune, DR - (2405)
11.562 @ 118.82 - MCV - 08 M6 Z51 - CAI, DR - (1848)
11.672 @ 118.89 - Justinjor - 08 M6 Z51 NPP - CAI, hdr, ptb, Removed fuse, DR - (5340)
11.688 @ 121.22 - Socalz06 - 08 A6 - CAI, hdr, DR - (2590)
11.706 @ 118.54 - Z51 6spd - 08 A6 Z51 NPP - Ewp, hdr, tune - (2171)
11.726 @ 118.81 - BSPC608 - 08 A6 Z51 NPP – CAI, hdr, tune, DR - (4421)
11.769 @ 120.88 - Dev1360 -09 M6 - CAI, cb, hdr, Nitto - (6704-16)
11.796 @ 122.65 - Y2K2Z28 -08 A6 Z51 - CAI, cb, hdr, tune, Ivos - (3785)
11.803 @ 121.56 - Cdaniel525 -08 M6 - CAI, hdr, no cats, Z06 exhaust, tune - (5437)
11.876 @ 121.93 - Chets LS3 - 08 M6 - CAI, hdr, tune - (6723)
11.881 @ 120.10 - SK360 - 08 A6 2.73 - hdr, Z06 muff tune, DR - (6720)
11.922 @ 118.74 - JAvery20 - 08 A6 NPP - CAI, tune BFG - (6721)
11.942 @ 119.44 - Corvet786C - 08 M6 - cb, hdr, 3.90, DR - (5854)
11.989 @ 120.04 - Rock n' Blue08 - 08 M6 - CAI, 3.90, hdr, Xpipe, Z06 muff - (2890)
11.992 @ 120.25 - HeavyRightFoot - 08 M6 Z51 NPP - CAI, hdr, tune - (4432)
11.994 @ 120.44 - 1.8T - 08 M6 Z51 - CAI, cb, hdr, tune, DRs - (2464)
11.995 @ 118.34 - Oklahoma - 08 A6 Z51 NPP 2.73 - Z06 exhaust & h pipe, P2s - (5718)
12.017 @ 119.91 - Insom - 09 M6 Z51 NPP - CAI, hdr, pi, ud, tune, DR - (4473)
12.016 @ 116.26 - Pettvette - 08 A6 - propped shroud no af - (4598)
12.033 @ 120.42 - Quikag - 08 M6 Z51 - CAI, cb, hdr, tune - (2525)
12.034 @ 119.35 - SeeFiveOhFun - 09 A6 - Con Dws Tires,cut shroud - (6551)
12.041 @ 115.99 - Bain - 08 A6 NPP 2.73 - CAI - (3525)
12.058 @ 118.15 - DarthOctane - 08 A6 NPP - DR - (6327)
12.103 @ 118.03 - TorchZ06 - 09 A6 NPP 2.73 - CAI - (4220)
12.118 @ 116.77 - MBB - 08 A6 Z51 NPP 2.73 - CAI, hdr, tune, nittos - (6488)
12.122 @ 118.06 - Badassbu - 09 A6 NPP - Removed fuse - (3141)
12.144 @ 118.12 - Crisis - 09 A6 Z51 - Cai - (5234)
12.179 @ 117.24 - QuickZilver - 08 A6 Z51 NPP - Removed fuse - (3540)
12.231 @ 116.61 - Danieloneil01 - 08 M6 NPP - Hdr, NC, nittos - (5703)
12.267 @ 117.52 - Ragtop99 - 08 M6 Z51 - CAI, hdr - (3927)
12.344 @ 118.40 - Airbuspilot - 08 M6 - CB - (3711)
12.410 @ 119.65 - PeterPan - 09 A6 2.73 - CAI, Tune ZR1 exhaust, 325 generals - (5902)
12.467 @ 117.86 - MMartin - 08 A6 Z51 - CAI, hdr, tune - (2906)
12.561 @ 114.70 - Gfish - 08 A6 Z51 NPP - CAI, tune - (5181)
13.336 @ 113.31 - Gaussian Mist - 08 M6 F55 NPP - Npp comander - (2704)
External Engine Modifications Grand Sport (Bolt-Ons)
11.528 @ 121.89 - GrandSportMan -10 A6 - CAIHM, hdr, tune, - (5572)
11.945 @ 118.55 - Agent White - 10 A6 NPP - CAI, hdr, tune - (4577)
12.185 @ 116.72 - EBF2K - 11 A6 NPP - CAI, hdr, tune, Ivos - (6398)
12.400 @ 115.45 - Thomasmoto - 11 A6 NPP - M2W switch - (6037)
12.696 @ 113.31 - EBF2K - 11 A6 F55 NPP - Cai, Forgeline rims, Nittos - (6248)
Internal Engine Modifications LS2
10.157 @ 129.43 - Stanger383 - 05 A4 - CAI, conv, 3.42, H&C, hdr, ptb, Z06muff, tune, & more, DR - (6370)
10.163 @ 131.08 - Dennis50NJ - 05 A4 Z51 - CAI, cb, conv, ewp, pfast, 3.73, H&C, hdr, ptb, tune, & more, DR - (6493)
10.585 @ 131.43 - DSP300C - 07 M6 – al/fw, CAI, cb, ewp, pfast, 4.10, H&C, hdr, 100maf, tune, DR - (4330)
10.665 @ 133.29 - Braciole - 07 M6 - CAI, cb, dp, ewp, pfast, 4.10, hdr, H&C, tune, DR - (4296)
10.672 @ 128.31 - Justasheet - 05 A4 Z51 - CAI, cb, H&C, conv, pfast, 3.73, hdr, ptb, mh, Z06 Muff, tune, DR - (6510)
10.815 @ 128.07 - Joe G - 05 M6 Z51 - CAI, cb, cam, pfast, 4.10, hdrs, tune, DR - (5758)
10.821 @ 127.85 - Silver93vert - 06 A6 - CAI, conv, fast, H&C, hdr, udp, tune, & more DR - (4579)
10.844 @ 125.83 - Tony B4 - 06 A6 - CAI, cam, cb, conv, hdr, ported int/tb, udp, tune, DR - (4010)
10.87x @ 125.33 - Tek-Newbie - 05 A4 - CAI, cb, conv, fast, 3.42, H&C, hdr, tune, DR
10.908 @ 126.00 - Thesubfloor - 07 A6 - CAI, cam, conv, 3.42, hdr, tune, DR - (3687)
10.967 @ 125.59 - Mike4572 - 07 A6 - CAI, cam, conv, 3.42, hdr, pi/tb, Z06 Muff, tune, DR - (4412)
11.002 @ 124.60 - EvlJake - 07 A6 - Cai, cam, conv, cb, hdr Ls3 heads, tune, udp, Dr - (6384)
11.013 @ 127.04 - Pete@Championmotors - 06 A6 F55 - CAI, cb, conv, 3.15, H&C, hdr, tune, DR - (4611)
11.034 @ 126.46 - Isaiah48 - 05 M6 Z51 - CAI, cb, 3.90, H&C hdr, tune, DR - (3918)
11.062 @ 122.05 - Huggerorange73 - 06 A6 Z51 - Cam, cb, conv, fast, hdr, tune, udp, DR - (6717)
11.192 @ 124.17 - C6Jack - 06 A6 - CAI, cam, cb, conv, hdr, pi/tb, udp, DR - (4256)
11.199 @ 123.05 - Evilways - 06 A6 Z51 - CAI, cb, cam, hdr, L92/L76 combo, tune, Dr - (4075-76)
11.201 @ 120.19 - C6Dreamvette - 05 A4 - CAI, cam, conv, hdr, no muff, tune,DR - (2470)
11.23x @ 123.00 - Texas Ranger - 07 M6 - CAI, cb, cam, 4.10, hdr, udp, tune, Z06 tires - (1692)
11.243 @ 123.05 - Its Stock - 06 M6 - CAI, cam, hdr, udp, tune, DR - (5084)
11.247 @ 126.33 - Sebaj - 05 M6 - CB, Z06 Ex, H&C pi/tb, QA1 shocks, ud, Tune DR - (5934)
11.354 @ 121.70 - C6speedjon - 07 M6 Z51 - CAI, cb, cam, pfast, hdr, ptb, tune, DR - (3468)
11.390 @ 105.83 - Firefighter813x - 06 A6 Z51 - CAI, cb, 3.15, H&C, hdr, ptb, tune, , DR - (6630)
11.467 @ 122.96 - Superstock1200 - 06 A6 - CAI, cb, cam, hdr, pi tune, DR - (2572)
11.49x @ 125.62 - Wa$nt me - 06 M6 Z51 - CAI, cb, cam, fast, hdr, udp, tune, DR - (1606)
11.514 @ 122.48 - GTkiller97 - 05 M6 Z51 - CAI, cam, fast, hdr, tune, DR - (5462)
11.52x @ 125.73 - High Roller1 - 06 A6 Z51 - CAI, cb, H&C, hdr, udp, tune, DR - (1905)
11.535 @ 124.97 - Boiler RXC6 - 05 M6 F55 - CAI, cb, fast, H&C, hdr, tune, DR - (867)
11.552 @ 126.31 - Bowmanized - 07 M6 - CAI, cb, pfast, H&C, hdr, susp, tune, DR - (2757)
11.76x @ 116.76 - 1955 Belair - 05 A4 Z51 - CAI, cb, conv, fast, H&C, hdr, tune, DR
11.790 @ 120.12 - Greentank - 06 A6 - CAI, cb, 3.15, H&C, hdr - (1817)
11.982 @ 120.87 - Mr Z51 - 06 M6 Z51 - CAI, cam, 4.10, hdr, pi, udp, tune, DR - (1261)
11.994 @ 120.11 - Turboffr - 06 M6 Z51 - CAI, cam, hdr, fast udp, tune, DR - (4461)
12.31x @ 119.28 - Black02SS - 07 M6 - CAI, cam, hdr, tune
12.410 @ 120.10 - Covert Guy - 05 M6 Z51 - cam, hdr, tune - (5700)
13.12x @ 119.00 - Mitchell242 - 05 M6 - CAI, cb, fast, H&C, hdr, tune
Internal Engine Modifications LS3
10.374 @ 133.59 - Matt@TuneTime - 08 M6 Z51- Cai, ewp, fast, hdr, H&C, 4.10, skinnies, tune, DR - (6378)
10.601 @ 125.49 - Bspc608 - 08 A4 Z51 NPP - CAI, cam, conv, 3.42, hdr, udp, tune, DR - (6587)
10.611 @ 131.81 - Turbovic - 08 M6 - cam, gto skinnies, hdr, mh, pi, tune, Z06 susp, tune, DR - (4609)
10.629 @ 126.77 - Shane Fap - 08 A6 - CAI, cam, conv, fast, hdr, tune, Z06 muff, Nittos - (6695)
10.633 @ 132.44 - Max@Cartek - 08 M6 - Cartek 4X H&C package, DR - (3640)
10.662 @ 131.68 - Doug@ECS - 08 M6 Z51 NPP - Blistens, cai, 3.90, H &C, hdr, tune, DR - (3193)
10.673 @ 129.31 - Justinjor - 08 M6 Z51 NPP - CAI, cam, hdr, ptb/int, no fuse, skinnies, udp, tune, Zo6spring DR - (5904)
10.739 @ 131.28 - Ls3yeager - 08 M6 - CAI, cb, cam, gto skinnies, hdrs, pi/tb, udp, tune, DR - (3968)
10.793 @ 127.17 - Theofel - 08 A6 - CAI, cb, cam, conv, ewp, 3.15, hdr, tune, & more, DR - (5086)
10.996 @ 130.13 - AndrewZPSU -10 A6 NPP - CAI, cam, hdr, mhvj, ptb, tune, DR - (5571)
11.032 @ 126.93 - Socalz06 - 08 A6 - CAI, cam, conv, hdr, tune, DR - (3896)
11.109 @ 123.70 - Xstang - 08 A6 - CAI, cam, conv, hdr, shaneTB, tune, DR - (4069)
11.143 @ 129.27 - AndrewZPSU - 08 M6 - CAI, cam, hdr, Z06 Exhaust, tune, DR - (4211)
11.179 @ 120.58 - Texasranger - 08 A6 - CAI, cam, 3.15, hdr, tune, DR - (2801)
11.527 @ 125.42 - CBVette - 08 A6 - CAI, cam, 3.15, hdr, tune, DR - (2801)
11.946 @ 121.11 - Beefcake - 08 M6 - CAI, cam, hdr, udp, tune, DR - (5936)
Internal Engine Modifications Grand Sport
10.982 @ 124.94 - Amwells1 -12 M6 - CAI, cam, hdr, tune, DR - (6721)
Power Adders LS2 (supercharger, turbo, nitrous)
09.668 @ 141.15 - Tucan26 - 05 A4 - SC, alky, cam, conv, fast, hdr, RPM trans, tune, DR - (6724)
09.732 @ 143.17 - Doug@ECS - 05 A4 F55 -Novi 2200, alky, cam, conv, 3.42, hdr, RPM trans, tune, DR - (3258)
09.936 @ 136.88 - Tekhombre - 05 A4 - SC, Cartek cus fuel sys, H&C, hf cats, HD rad, tune, DR - (1153)
09.984 @ 135.44 - Shoaf85 - 07 M6 – Upp Twin Turbo, drag pk, fuel sys, twin disk, 4.10, tune, DR - (6363)
10.065 @ 141.65 - Jutskin - 05 A4 Z51 – SC Cam, coil overs, Flipdrive, Fast 3.42, Z06rear, & more, DR - (5901)
10.154 @ 139.08 - Devilish34 - 07 M6 - SC, hdr, meth, pintake, Z06 rear, tune, DR - (6701)
10.227 @ 143.70 - FactoryRaceCar - 05 A4 – TTurbo & alky, conv, 3.42, Z06rear, RPM Trans, tune, & more, DR - (5375)
10.420 @ 133.25 - RealCanuk - 07 A6 NPP - SC, gears, hdr, HFcats, tune, DR - (6311)
10.582 @ 135.54 - BMT03-mach1 - 05 M6 - N2O, CAI, cam,no cats, tune, DR (6565
10.665 @ 136.52 - Carlrx7 - 06 M6 Z51 – TTurbo & E85 pfat coil overs, tune, udp, DR - (5544)
10.680 @ 136.70 - N77nxc - 07 A6 - SC, CAI, cam, conv, hdr, DR - (4217)
10.866 @ 125.30 - JerryMuniz - 05 A4 - N2O, CAI, cb, conv, 3.73, hdr, tune, DR - (476)
10.899 @ 129.93 - DTE - 05 A4 – Twin Turbo, gears, muff, DR - (935)
10.905 @ 134.14 - Javw - 07 M6 – APS Twin Turbo, bilsteins, tune, DR - (6357)
10.996 @ 125.65 - Z51 6spd - 06 A6 Z51 - SC, CAI, cb, hdr, tune, DR - (3296)
11.074 @ 127.62 - Nextphasemarko - 06 A6 Z51 - MC, cb, hdr, DP, tune, DR - (3661)
11.094 @ 128.62 - Soldsyclone - 06 A6 - N2O, CAI, hdr, DR - (2820)
11.18x @ 125.42 - Stuart3232 - 06 M6 Z51 - N2O, CAI, CB, DR
11.281 @ 131.61 - Salvitale - 07 M6 Z51 - SC with meth, cb, hdr, tune, DR - (1800)
11.285 @ 126.48 - MCV - 06 A6 - SC, CAI, cb, tune, DR - (1648)
11.316 @ 123.93 - Ponchorello - 05 A4 - N2O, CAI, cam, hdr, tune, DR - (1896)
11.370 @ 135.29 - Turboffr - 06 M6 Z51 - SC, cai, cam, fast hdr, meth, udp, tune, DR - (4516)
11.379 @ 126.64 - Nine Ball - 05 M6 Z51 - SC, cb, cam, hdr, tune, DR - (589)
11.402 @ 121.47 - C6 Roller - 05 A4 - SC, hdr, tune, DR - (1768)
11.482 @ 120.98 - AngeloC6 - 05 A4 3.15 - SC, cb, tune - (6600)
Power Adders LS3 (supercharger, turbo, nitrous)
09.556 @ 144.52 - Gsbowman - 08 A6 - SC, cam, conv, 3.42, hdr, Z06 muff, & more, tune, DR - (5347)
09.759 @ 139.83 - Silver Bullet C6 - 08 A6 - SC, alky, cam, cb, hdr, pi/tb, tune, DR - (4986)
10.034 @ 134.38 - Theofel - 08 A6 - SC, cam, cb, conv, 3.15, GTO sk, hdr, meth, pint/tb, tune, & more DR - (6617)
10.150 @ 138.16 - RV00GT - 08 M6 NPP - CAI, cam, hdr gto skinny, N2O, tune, DR - (6498)
10.248 @ 139.15 - Slowsome - 08 M6 F55 - ECS Novi, cb, fuel system, H&C, hdr, meth, tune, DR - (5556)
10.276 @ 135.55 - Detoxx03 - 08 M6 - SC, alky, cam, pfadt, tune, DR - (6545)
10.551 @ 135.06 - The Game - 08 M6 Z51 NPP - ECS Novi2000, alky, hdr, tune, DR - (3232)
10.575 @ 135.18 - Winters 97 GT - 08 M6 - SC, alky, B&B mufflers, tune, DR - (5029)
10.704 @ 136.61 - ZbadestZ - 08 A6 NPP - ECS 2200, hdr, fuel system, tune DR - (5021)
10.732 @ 133.32 - Deecount - 09 A6 F55 NPP 2.73 - SC, boost a pump, tune, DR - (6262)
10.872 @ 131.13 - Beefcake - 08 A6 - CAI, cam, hdr, SC, tune, DR - (3899)
10.879 @ 129.37 - ShawnBrumley - 08 A6 - Eforce SC, tune, DR - (6627)
Power Adders Grand Sport (supercharger, turbo, nitrous)
10.368 @ 137.29 - DCI - 11 M6 GS - SC, cam, hdr,smaller pulley, tune, DR - (6449)
10.657 @ 134.70 - Fordracer9 - 10 A6 GS - SC, hdr, meth, xpipe, tune, DR - (5654)
11.329 @ 124.01 - CaptainBob - 11 A6 GS - Eforce SC, hdr, DR - (6507)
11.399 @ 123.44 - Thomasmoto - 11 A6 NPP - Eforce SC, hdr, M2W switch, DR - (6503)
Larger Displacement (All entries)
07.982 @ 174.44 - Tluck - 05 A4 Z51 - 427cid, turbo, power glide, eldbrock intake, coil overs, & more, tune, DR - (6296)
09.513 @ 148.77 - Todd@RPM - 05 A4 -TT, 427cid, fuel sys, 3.42, L92 heads, RPM Trans, tune, DR - (4274)
09.680 @ 139.20 - JThurik - 10 A6 GS - 377 forged internals, SC, hdr, meth, xpipe, tune, DR - (6722)
09.681 @ 148.36 - Winters 97 GT - 08 M6 - 402, SC, alky, B&B mufflers, tune, DR - (5881)
09.751 @ 147.05 - Icevettez06 - 05 M6 - 402 APSTT, alky, fast, fuel system, Z06 trans, more, tune, DR - (6301)
09.895 @ 138.76 - Blue RacerC6 - 05 A4 Z51 - SC LPE 427,N20 (100) & RPM trans, tune, DR - (4273)
09.950 @ 139.26 - Thesubfloor - 07 A6 – LS7, CAI, cb, conv, 3.42 H&C forged int, tune, DR - (4465)
10.231 @ 136.86 - Deecount - 09 A6 Npp 2.73 - SC LPE 427, cam & pheads Ls9 Intake, more tune, DR - (6727)
10.369 @ 134.42 - Pete Champion Motors - 06 A6 – LS7, cam, cb, conv, fast, 3.15, forged int, ph, tune, DR - (5153)
10.416 @ 132.71 - RGSTOY - 07 A6 Z51 – LS7, conv, 3.42, hdr, tune, DR - (4194)
10.470 @ 130.89 - Craftfox - 07 A6 Z51 – 440cid, conv, fast, 3.42, hdr, tune, DR - (4444)
10.529 @ 138.03 - Icevettez06 - 05 M6 - 402cid, apsTT, alky, fast, hdr, qual, tune, DR - (5297)
10.689 @ 133.21 - Schilitj - 05 M6 Z51 - 402cid, SC, cb, H&C, hdr , tune, DR - (3525)
10.761 @ 128.59 - MCV - 05 M6 - Callaway 550 package gears, DR - (778)
11.439 @ 124.43 - Sheesnaz - 06 A6 Z51 - 416cid, conv, pfast, H &C, ptb, tune, Nitto Ivos - (3736)
11.689 @ 122.42 - RDD41 - 06 A4 - LPE 403 package - (658)
1/8 mile Please submit complete 1/8 mile time slip (All entries)
6.114 @ 118.10 - Shoaf85 - 07 M6 – Upp Twin Turbo, drag pk, fuel sys, twin disk, 3.90, tune, DR - (6523)
6.519 @ 107.03 - Thesubfloor - 07 A6 - CAI, cam, conv 3.42, hdr, tune, & more DR - (4688)
6.945 @ 106.14 - Pmj341 - 07 A6 – CAI, conv, 427, fast, H&C, ptb, 100maf, tune, DR - (4357)
7.19x @ 97.56 - Socalz06 - 08 A6 - CAI, cam conv, hdr, DR - (3782)
7.145 @ 97.67 - Carlrx7 - 06 A6 - CAI, cam, conv hdr, tune, DR - (6393)
7.213 @ 95.10 - Joe G - 05 M6 Z51 - CAI, cam, 3.90, pfast, hdr, tune, DR - (3788)
7.279 @ 98.71 - XStang - 08 A6 Z51 - CAI, conv, hdr, ptb udp, tune, - (3786)
7.275 @ 92.27 - Sparo2 - 05 M6 Z51 – CAI, Cb, afw, ewp hdr, pi/tb, C5-3.90, tune DR - (4530)
7.342 @ 96.69 - Tony B4 - 06 A6 - CAI, cam, cb, conv, hdr, pi/tb, udp, tune, DR - (3052)
7.36x @ 98.03 - StageIt - 08 M6 Z51 -Cb, fast, hdr, 3.90, Et Street - (2863)
7.50x @ 99.47 - Vettechictwins - 08 M6 Z51 - CAI, cam, cb, pi/tb, hdr, tune PS2s - (3081)
7.65x @ 93.64 - C5Pilot - 07 A6 Z51 - CAI, pi & tb, hdr, tune Dr - (3558)
7.676 @ 94.37 - DavetteGuy - 08 A6 - CAI, Ptb tune - (5064)
7.835 @ 92.14 - Bunk22 - 05 M6 Z51 - CAI cb, hdr, pi, nitto ivos - (4160)
8.096 @ 91.07 - Carmos - 08 A6 Z51 NPP - (4042)
8.428 @ 85.00 - ByByBMW - 05 A4 3.15 – CAI, cb, tune - (1660)
Old Nov 21, 2013 | 11:28 AM
  #6724
JBrunoJSBC6's Avatar
JBrunoJSBC6
St. Jude Donor '14
Oh man, you butchered my name on the main list. lol
Old Nov 21, 2013 | 11:53 PM
  #6725
Tommy D's Avatar
Tommy D
Yup, I did but....... I left a space to remind myself to correct it and then forgot.
Old Nov 26, 2013 | 02:36 PM
  #6726
CUSVT's Avatar
CUSVT
Category:Ls3 Bolt on
2. A copy of your entire time slip posted to the thread as in post # 6728
4. Year Corvette 2008
5. Type of Trans A6
6. Type of Suspension Base
7. Stock Performance options: 2.56 gears 1LT
8. Tires utilized MT DR 275/40/17
9. Modifications: 1 3/4 LT's, CAI, Borla over axle, Shroud propped open
10. Dyno numbers if you have them: None
11. Left off idle in S mode.
12.
___ Texas Motorplex
___ October 25th 70 Degrees
___ 60'.............1.892
___ 330'...........5.116
___ 660'...........7.724
___ 660’ mph.....94.65
___ 1000'.......... 9.949
___ 1320'..........11.805
___ 1320’ mph….121.34
Hope I did this right. Thank you
Old Nov 30, 2013 | 10:47 AM
  #6727
tucn26's Avatar
tucn26
5. Type of Trans A4
___ Name of the Track No Problem Raceway
___ Date of the pass & weather conditions 11/29/13 55 degrees sunny
___ 60'............. 1.44
___ 330'........... 4.00
___ 660'........... 6.14
___ 660’ mph.... 116
___ 1000'......... 7.97
___ 1320'......... 9.52
___ 1320’ mph… 144
Old Nov 30, 2013 | 11:07 AM
  #6728
Joe_G's Avatar
Joe_G
St. Jude Donor '08
5. Type of Trans A4
___ 1320’ mph… 144
Great pass! I think that's a new record run right there.
How many passes do you have on the stock 05 rear, or have you upgraded it?
Old Nov 30, 2013 | 11:13 AM
  #6729
tucn26's Avatar
tucn26
Joe, I have well over 250 passes on the stock 05 diff. Since the tracks are coming to a close for a few months I'm going to upgrade it. Still unsure on which unit to go with and keeping stock gears or change them...
Old Nov 30, 2013 | 11:19 AM
  #6730
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Fantastic. Folks think they are made from glass, and while they are weak, they are not made from glass. I got 301 passes from mine. The killer is wheel hop and with DR's I never have it.
You should ask Subfloor (Christopher) his opinion on gears with a stalled auto as well as Stanger383 (Norm). Those gents have the experience you seek and will give good advice.
Old Nov 30, 2013 | 11:20 AM
  #6731
tucn26's Avatar
tucn26
I agree! I will do that for sure, I'm hoping it have it back together within two weeks, so i will have to get some good info pretty quick.
Old Nov 30, 2013 | 11:30 AM
  #6732
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Let's see if they chime in......I sent them a note and both are usually great about helping a fellow Vette owner.
Old Nov 30, 2013 | 11:40 AM
  #6733
stanger383's Avatar
stanger383
St. Jude Donor '09
Christopher has bolted in several gear ratios so he can chime in on the differences as far as they go. I personally have only ever run the stock 3.42 in my cars. When I converted from the stock 05 dif I put a C 5 Z dif with the stock 342 gears and it held up to low 1.3 60 foots..
Basically you have 2 options. You can install a c 5 z dif (with 3.42s already in)into your car by fabricating brackets or I make a set that allows it to be a direct bolt in. The other option is to contact rpm transmissions. they make an adapter plate to bolt a 06 up c6 dif into your 05. As far as us Auto(A4) guys go, there is no need to have a lot of gear in the car.. Personally I feel unless you are running a 28 inch tall tire that the 3.42 will work for almost all cases
Old Nov 30, 2013 | 11:54 AM
  #6734
tucn26's Avatar
tucn26
Basically you have 2 options. You can install a c 5 z dif (with 3.42s already in)into your car by fabricating brackets or I make a set that allows it to be a direct bolt in. The other option is to contact rpm transmissions. they make an adapter plate to bolt a c6 def into your 05. As far as us Auto guys go there is no need to have a lot of gear in the car.. Personally I feel unless you are running a 28 inch tall tire that the 3.42 will work for almost all cases
I'm pretty much set on going to 3:42s. Im glad you said they wouldnt be a bad choice. If i went the c5z route how would that compare to say the rpm level 1 or 2 diff? I just dont want to swap and have to do it again within a few months. Price is also a big factor in that with the c5z being fairly easily had and for alot less than the RPM unit.
Old Nov 30, 2013 | 02:26 PM
  #6735
Kuhnrod's Avatar
Kuhnrod
Category : GS - Stock
4. Year Corvette 2010 GS
5. Type of Trans A6
6. Type of Suspension GS
8. Tires utilized OEM
9. Modifications if any None
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc - 62 degrees; fronts at 37 lbs, rears at 28 lbs; launch from 1500rpm; ¼ tank gas
___ Name of the Track – Gateway-St. Louis
___ Date of the pass & weather conditions Nov 9, 2013 – 62 degrees
___ 60'............. 2.003
___ 330'........... 5.403
___ 660'........... 8.154
___ 660’ mph.... 89.62
___ 1000'......... 10.50
___ 1320'......... 12.463
___ 1320’ mph… 115.25
Old Nov 30, 2013 | 07:25 PM
  #6736
C7/Z06 Man's Avatar
C7/Z06 Man
Default Please Update= Grand Sport (Bolt-ons)
Went to the track today. I started out by knocking down an 11.41 @ 122.80 with a 1.75 60 ft. time running the "Bridgestone" Runflats which the rear tires alone weigh three pounds more each than the OEM Goodyear runflats. I weigh 260 lbs.
Than a guy running a Z06 let me use his Hoosier 315/35/17's on much lighter Z06 rims. My 60 ft. stayed the same but the lighter wheel/tire made a difference in ET & MPH. Now I'm thinking a converter and skinnies.
Category: External Engine Modifications Grand Sport (Bolt-ons)
4. Year Corvette= 2010 Grand Sport
5. Type of trans= A6 with Stock Converter
6. Type of suspension= Stock
7. Stock Performance options= None
8. Tires utilized= 315/35/17 Hoosier drag radials
9. Modifications if any= 1) C.A.I., using a modified "OEM" housing. 2) 1 3/4" Headers with the stock "430 HP" Mufflers. 3) Intune "Canned" 93 octane tune.
10. Dyno numbers if you have them= None
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc.
I did a burnout than an approx. 1200 RPM launch in "S" mode with just "traction control" turned off.
12. Type in post (as some time slips get deleted & etc. after posted).
_Name of track: Cecil County Dragway
_Date of the pass & weather conditions: 11/30/13, approx. 34 degrees.
_60'........... 1.751
_330'......... 4.826
_1/8.......... 7.348
_1/8 mph... 96.74
_ 1000'...... 9.508
_1/4.......... 11.328
_1/4 mph... 125.03
Old Nov 30, 2013 | 08:53 PM
  #6737
ShaneFap's Avatar
ShaneFap
^ holy **** what was the DA.... i wish i could race in 34* weather.
To C6 1/4 Mile Performance Challenge
Old Nov 30, 2013 | 10:04 PM
  #6738
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Dragtimes says it was -2124. Doesn't get too much better although dew point was kind of high with 60% humidity. 30.68 baro is great.
Can't imagine there was much traction in that weather...1.7 60 foot is very respectable from a stock converter but I wonder if the track was holding anything lower than that.
Grandsport man did you see any 1.4 60 foots?
Old Nov 30, 2013 | 10:07 PM
  #6739
tucn26's Avatar
tucn26
I posted the video of this run on my thread in the if section if you want to check it out!
Old Nov 30, 2013 | 10:12 PM
  #6740
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Holy crap that run looks FAST! Car sounds mean too. Way to go.
