LS2 Hp w/Maggie???
Old Dec 21, 2007 | 11:14 PM
96Magnuson's Avatar
96Magnuson
Default LS2 Hp w/Maggie???
What is your HP ratings with stock bottom end and top?List your mods also please..
Old Dec 22, 2007 | 12:12 AM
johnodrake's Avatar
johnodrake
Moderator
LPE Says: http://www.lingenfelter.com/pack_cor_c6.htm
Old Dec 22, 2007 | 02:34 AM
ChargedC6's Avatar
ChargedC6
my stock tune on the maggie flash with no headers just the maggie kit was 460whp 439wtq. 5lbs of boost. going in for a tune and 8lbs in a week or so
Old Dec 22, 2007 | 08:24 AM
96Magnuson's Avatar
96Magnuson
What size pulley are you going with to get to 8..
Old Dec 22, 2007 | 12:12 PM
musclecar6's Avatar
musclecar6
Have an 06 A6/F55 with an excellent LPE Maggie install, 471 rwhp & 443 rwtrq. Has run flawlessly since install 11,000 miles ago. 17000 miles on the car.It has an LPE tune & I believe it's at 7 psi.
Old Dec 22, 2007 | 12:50 PM
ChargedC6's Avatar
ChargedC6
3.1 will get you 7-8lbs.
Old Dec 22, 2007 | 01:07 PM
NemesisC5's Avatar
NemesisC5
Old Dec 22, 2007 | 02:19 PM
ChargedC6's Avatar
ChargedC6
sounds pretty low for 7psi. you sure its not the stock pully? 7psi you should def be over 500whp. either that or your rich as hell. but if its tuned my LPE i doubt that.
Old Dec 22, 2007 | 10:13 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
492hp, btw.. I sold the Maggie. and the car!
Old Dec 23, 2007 | 09:02 AM
Bushong572's Avatar
Bushong572
'06 A6 Lingenfelter..........503 rwhp/497 rwtq
3.0" pulley (6-7 lbs of boost)
1 7/8" headers
LPE MAF
BTW: If your not running headers, I would change the pulley to a 3.2 (stock 3.4 pulley will be around 5.5 lbs of boost with stock manifolds....the 3.2 will be 6.5- 7 lbs). If your running headers, I would go with a 3.0 pulley (you'll be lucky to get 7 lbs with the 3.0 and headers). I highly recommend going with a Reichard Racing pulley and Goodyear Gatorback belt (no slippage). I've seen many Magnuson pkgs.....I would not run the 112 over 7 lbs of boost (the case can only flow so much and becomes very inefficient). If you want more out of a maggie, buy the 122.
To LS2 Hp w/Maggie???
