DIC says "Low Oil Pressure"
Old Dec 25, 2007 | 01:29 PM
schilitj's Avatar
schilitj
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Default DIC says "Low Oil Pressure"
This started yesterday---
Start the car up and the DIC says Low Oil Pressure and the oil pressure gauge sits at 0. The idiot light does not light up.
When I start the car the oil gauge goes all the way up then returns and sits at 0. Had the oil changed (royal purple) 300 miles ago. Dip stick indicates oil at proper level.
Yesterday, after a few minutes the pressure returned, today, it's sitting at 0.
Several conclusions:
1. sending unit is bad
2. oil gauge is bad
3. oil pump is bad
What to do:
drive it to my shop Horsepower Sales about 10 miles from home,
or,
have it flatbedded there?
Thanks.
Old Dec 25, 2007 | 01:53 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
2. oil gauge is bad
3. oil pump is bad
What to do:
or,
Thanks.
Two of the 3 won't kill ya. The third is engine destructive.
I'd flat bed it.
Elmer
Old Dec 25, 2007 | 02:00 PM
timd38's Avatar
timd38
Flat bed.
Old Dec 25, 2007 | 03:40 PM
johnodrake's Avatar
johnodrake
Moderator
I agree with the preceding, unless you are a gambling man...
Old Dec 25, 2007 | 03:48 PM
CHASLS2's Avatar
CHASLS2
St. Jude Donor '13
No oil pressure can = BOOM. Have it towed.
Old Dec 25, 2007 | 04:03 PM
carpe dm's Avatar
carpe dm
Originally Posted by timd38
Flat bed.
Probably (we all hope) a sensor, but why take the chance. Good luck.
Old Dec 25, 2007 | 04:25 PM
07MontRedcp's Avatar
07MontRedcp
Wouldn't the lifters be clattering if there was indeed a bad pump??
If the idiot light didn't come on I'm thinking it is the gauge or an intermittent electrical connection.
BJK
Old Dec 25, 2007 | 04:41 PM
eboggs_jkvl
Moderator emeritus
My car insurance covers tows. Why the hell would I give it a 2nd thought as to what it could possibly be? Tow it and move on.
Old Dec 25, 2007 | 05:13 PM
johnodrake's Avatar
johnodrake
Moderator
BJK
You are probably right - but the cost of being wrong is high.....
Old Dec 25, 2007 | 05:56 PM
schilitj's Avatar
schilitj
No lifter chattering
Not taking any chances
Flatbed to the shop in the morning.
Thanks for the comments.
Old Dec 25, 2007 | 07:06 PM
RICH 28's Avatar
RICH 28
Let us know what it was. Good luck to ya.
Old Dec 26, 2007 | 12:08 PM
Oldvetter's Avatar
Oldvetter
There is a fourth possibility, that your oil pressure bypass (in the block) has debris in it and it is "stuck" partially open. Unfortunately, you have to disassemble past replacing the oil pump to see this (and this is almost to the point of replacing the cam).
Old Dec 26, 2007 | 01:13 PM
schilitj's Avatar
schilitj
A couple of the guys from Horsepower Sales (Jeremy and Tim) came to the house to check this out. Their initial guess is a bad sensor. Car just left, flatbed, for their shop. They will swap one out as soon as it gets there and let me know if it was, I hope, a simple fix.
Old Dec 26, 2007 | 01:19 PM
Cory@LS2PortWorks's Avatar
Cory@LS2PortWorks
St. Jude Donor '09
If you've had the intake manifold off at all, I would do a simple check...
-Reach behind the intake manifold on the driverside (under the cowl)
-Locate the large vacuum hose connection on the intake manifold
(brake booster line)
-You should be able to feel the oil pressure sensor and the wires for it as the electrical connection is right there.
-Make sure the plug is properly connected and fully seated.
If not... you can see intermittent things like you've mentioned. It's a 5 minute check that can save you the time of the other options.
Here's a link to a picture... step 7 pertains:
http://www.ls2portworks.com/Installation.html
Old Dec 26, 2007 | 02:33 PM
schilitj's Avatar
schilitj
Cory
Thanks, that is exactly what they did when they were at the house. The car is now at their shop and they're going to swap out the sensor from another C6 to see if that is the issue.
Jeff
Old Dec 26, 2007 | 08:44 PM
schilitj's Avatar
schilitj
Default And the finding is:
The oil pressure sensor behind the intake manifold was bad. Replaced it and oil psi immediately returned.
Old Dec 26, 2007 | 09:12 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Great news! And perhaps people will start to see why we HPSFlorida customers are so loyal...
how many shops do house calls????
To DIC says "Low Oil Pressure"
Old Dec 26, 2007 | 09:39 PM
schilitj's Avatar
schilitj
And, Joe, how many shops will have the President (Jeremy) of the company come to someone's house.
Old Dec 26, 2007 | 10:31 PM
glennhl's Avatar
glennhl
Great story about a dedicated shop!
Old Dec 26, 2007 | 11:16 PM
knkali's Avatar
knkali
I love hearing **** like this. Good outcome good shop good all around!
