Tri Y Headers
Old Dec 25, 2007 | 02:43 PM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
Default Tri Y Headers
Anybody tri / use them ?
http://www.bassani.com/part/604217C
Old Dec 25, 2007 | 02:51 PM
Nd4spd2's Avatar
Nd4spd2
St. Jude Donor '08
I had a set of Tri-Y headers back in the 70's on a Mustang I had, i really liked them. I don't remember the name brand though.
Old Dec 25, 2007 | 03:09 PM
glennhl's Avatar
glennhl
I know a number of NASCAR teams use Tri Y headers. They should work great on the LS2 or LS3. There are a number of people that have run them on C5's, you may want to do some searching over on the C5 forum.
Old Dec 25, 2007 | 07:29 PM
9secz's Avatar
9secz
With an O2 sensor controlled engine like ours I'd really worry about all those slip joints in front of the O2 sensors. If I had any trouble getting the AFRs right I'd always wonder if the headers were leaking.
Old Dec 25, 2007 | 08:25 PM
glenB's Avatar
glenB
That's really not a problem.
Before and after readings using similar style long tube 4 into1 headers and using a wideband O2 didn't show any significant changes to indicate a leak in the pipe joints. Just use a good o2 safe sealant like the 'Ultra' series of silicone sealant and there won't be any problems.
Old Dec 25, 2007 | 10:00 PM
Ragtop 99's Avatar
Ragtop 99
Mandrel bent 14 ga. Carbon steel primary tubes for durability.
...Standard finish is industrial chrome. High temperature ceramic coating is optional.
I'd get them coated.
To Tri Y Headers
