Need Answer for Z51 brakes
Old Dec 26, 2007 | 06:28 PM
rlee's Avatar
rlee
Default Need Answer for Z51 brakes
I need to know what parts are involved in changing a base 07 C6 brake to a Z51 brake. I'm sure of rotors, but what else is needed. Are the base calipers and pads the same as the Z51? Thanks in advance for your help.
Old Dec 26, 2007 | 07:08 PM
timd38's Avatar
timd38
Caliper brackets are the only other thing you will need.
Old Dec 26, 2007 | 08:56 PM
rlee's Avatar
rlee
Anyone else with experience. I would appreciate it greatly!
Old Dec 26, 2007 | 09:25 PM
corvette pilot's Avatar
0corvette pilot
Former Vendor
tim is right. There is a different compound for the Z51 pads, but they are the same size and interchange.
The rear Z51 caliper has a 3mm smaller piston, but that doesn't make a practical difference for daily driving.
Rotors and brackets are all you need, believe me, I know Corvette calipers!
Old Dec 27, 2007 | 08:54 AM
rlee's Avatar
rlee
ttt
Old Dec 27, 2007 | 09:07 AM
timd38's Avatar
timd38
Originally Posted by rlee
ttt
Maybe I don't understand the question, but if you have rotors all you need is brackets. I changed four rotors, pads and brackets in about an hour when the car was new. I have a Z51, but put Baer two piece rotors and ceramic pads on, so I had to take the brackets off to change the rotors.
Is there more to the question that I missed since you moved it to the top?
Old Dec 27, 2007 | 09:20 AM
FloydSummerOf68's Avatar
FloydSummerOf68
Yeah, your question was answered...all you need are rotors and brackets.
I'm doing the swap and bought rotors slightly used and brackets from scoggin dickey (way cheaper than gene's package deal). Got everything for 330 shipped...not bad
Old Dec 27, 2007 | 10:12 AM
Miaugi's Avatar
Miaugi
...OP must be looking for multiple members to confirm....so here's one more!
Old Dec 27, 2007 | 10:31 AM
rlee's Avatar
rlee
Thanks and you all have been more than helpful. Consider it well answered.
To Need Answer for Z51 brakes
