Diff DIY, any gotchas?
Old Dec 27, 2007 | 09:22 PM
Hooked4Life's Avatar
Hooked4Life
Default Diff DIY, any gotchas?
I have the manuals, 20+ years behind a wrench. I am considering swapping my own rear to save $500 or so. Are their any gotchas, or shortcuts from what is in the manual on a diff swap?
Old Dec 27, 2007 | 10:15 PM
Jim_H's Avatar
Jim_H
The manual sucks, check out these links. They're for a C5 but its nearly identical.
http://www.cajundude.com/differential.htm
http://mikemercury.home.att.net/342.htm
Old Dec 27, 2007 | 10:49 PM
oneblackvette's Avatar
oneblackvette
If you dont have a motorcycle jack, borrow one makes the job that much easier. I did mine by myself on the garage floor in under 4 hours. Petty cut and dry stuff.
Old Dec 27, 2007 | 11:23 PM
Hooked4Life
Thanks for the links!
Old Dec 28, 2007 | 03:58 PM
thesubfloor's Avatar
thesubfloor
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
I used a transmission jack when I did mine so I would strongly recommend renting one if you have to.
I also discovered that there are certain steps that you don't have to do as long as you're careful.
Feel free to PM me with any questions you might have.
Christopher
To Diff DIY, any gotchas?
