vararam now check engine
HPtuners website. Join and search for common topics such as what I posted:
http://www.hptuners.com/forum/index.php
C5 section tuning info fro term explanations. Takae a look at LTFT's:
http://www.c5forum.com/diy/ltft.php
Why you have a CEL:
http://www.magma.ca/~johnhunt/fbody/ls1_tune.html#trims
Here is the section you need:
Long Term Fuel Trim Description
The long term fuel trim (FT) is a matrix of cells arranged by RPM and MAP. Each cell of the long term FT is a register like the short term FT. As the engine operating conditions change, the PCM will switch from cell to cell to determine what long term FT factor to use in the base pulse width equation.
While in any given cell, the PCM also monitors the short term FT. If the short term FT is far enough from 0 percent, the PCM will change the long term FT value. Once the long term FT value is changed, it should force the short term FT back toward 0 percent. If the mixture is still not correct (as judged by the PCM), the short term FT will continue to have a large deviation from the ideal 0 percent. In this case, the long term FT value will continue to change until the short term FT becomes balanced. Both the short term FT and long term FT have limits, which vary by calibration. If the mixture is off enough so that long term FT reaches the limit of its control and still cannot correct the condition, the short term FT would also go to its limit of control in the same direction. If the mixture is still not corrected by both short term FT and long term FT at their extreme values, a FT DTC will likely result. When the PCM determines that the long term FT is out of the operating range, the following DTCs will set:
DTC P0171 FT System Lean Bank 1
DTC P0172 FT System Rich Bank 1
DTC P0174 FT System Lean Bank 2
DTC P0175 FT System Rich Bank 2
Under the conditions of power enrichment, the PCM sets the short term FT to 0 percent and freezes it there until power enrichment is no longer in effect. This is done so the Closed Loop factor and the long term FT will not try to correct for the commanded richness of power enrichment.
The ability of the PCM to increase or decrease long term fuel trim adjustments is +/- 25% in either direction (23% and 13% for 01's and up). It will set a diagnostic code. At that point, you are forced to look at your system and either remedy it by go back to where you were, or tuning your system, and/or adding larger injectors, etc.
The one area not agreed with by most tuner platform developers isthat the car adds fuel in PE mode in addition to the commanded a/f by calculating the amount lean it was in closed loop. Those that scan with a wideband as I do not e the car is way richer if there are positive LTFT's than if they were non-positive including zero.
SpinMonster, is there any advantage to removing the restrictive MAF screen? Is there any hp gains by the removal? I have a ported and polished TB with Vararam.
Started it, gave it the once over, still checked out, so off the stands & off I went. When I started the car off the jacks, bam, CEL! So much for sweet success. Took it out for a 20 miles run half city streets half highway. Engine light still on. Gave a quick once over from what I could see, nothing noteable. Parked it & started cleaning up garage.
When I started it put it away, no CEL, again, sweet success! Took for a short spirited run, very impressed w/ sound & sotps improvement, also noticed more tire spin, i.e. HP?
Finally, started it once more 30 min later, no CEL! Awesome, & honestly the car has never felt stronger, maybe its the cool temp, & just the sound, I would swear to marked improvement.
Next, FAST install, modified by Spin (awesome job thank you very much) then off for a cam & tune. I am very curious what the impact of the FAST will be. When installed, the mods. will be as follows:
Vararam w/ spacer
1-3/4 Kooks 3" x-pipe
3" back to 2-1/2 Flowmaster connect
Flowmaster 17427
Fast 90 (mild self port)
Anyone have a guess where I'll be rwhp, pre-tune?
A tune will end it forever.
Spinmonster, not to hijack too much, but I've been complaining about a hesitation from throttle depression to the car revving up ever since I installed a ported throttle body. I still have my MAF screen in. I've got my LTFT's to -2 across the board and 0 at idle. The hesitation causes me trouble heel-n-toe downshifting as the car isn't as responsive as I like.
From your post it sounds like a MAF scale might be in order. I've kept the stock scale even with my cam, I just adjusted it at idle to get 0 ltft's at idle and adjusted be VE table to get the rest of the trims in order.
Would you mind emailing me your MAF tables so I can see the scaling?
Here's what I do in my shop.....
Log your LTFT's by MAF HTZ. Basically, you need to make a LTFT table that reflects the same MAF Htz columns of your MAF calibration.
Then log the fuel trims. on a good ride trying to hit as many cells as possible.
The way it works..... If at 3600 Htz, you're reporting a LTFT of 15, then make a positive adjustment to that cell of the MAF table by only about 50% or so of the actual LTFT (or AFR Error). Do this for all areas of the LTFT table you created until you have roughly positive 5 in your fuel trims from the bottom of the table to about 7,500 htz. Try to get the 7,500-12,000 fuel trims to 0 (zero).
This will make the car run the best it can run without getting too scientific.
REMEMBER: If you're gonna get a "check engine" light for the LTFT's, it will usually occur when a particular cell goes above positive 20. DO NOT DISABLE THE LTFT CODE! It's important.
Sometimes when installing a high quality (HIGH FLOW) intake system like the VARARAM, it's not likely you'll get a light, but every car and system is different. Porting the TB will make it worse, so will headers and the like.
For those of you out there that are not MAXX EFFORT with your vehicles....Do yourself a favor and leave the MAF SCREEN in place.
Likely, SPIN and other tuners will have different opinions on this, but...This basic approach will make your car run great and not give you any problems.
For anyone who has a light on or just wants the VARARAM-MOBLIE you're driving to be the best that it can be.....
PLEASE SEE MY MAIL ORDER TUNING THREADS ON THIS FORUM.
It's NEW YEARS! And I'm OUTA HERE!
Chuck CoW
07 Z51 vert
vararam intake w/ spacer
dynatech headers/cats/xpipe
borla sport cat back
and it will be tuned with an LS1 edit
07 Z51 vert
I gained 17hp just with the AR header install on my 06 a6, then after the tune 30hp and 24 ft lbs.
Tuning gets the LTFT's to be non positve near zero which is the same 14.7 it always is but it wont dump more fuel than commanded in WoT.
The cam's breathing requirements would be helped by the FAST manifold. You will be fine driving to get the cam installed. The manifold typically makes you 3% leaner on the LTFT's. It snt that much worse.
Too bad about LS1 edit though. What do they charge?
Mine was free and you could have saved the money. You went where you felt comfy.
